26R Wheel dimensions
PostPost by: Davidb » Tue Jan 31, 2017 3:15 am
I am in the process of adapting a set of Revolution wheels to 26R knock-on hubs but I need dimensions. Could somebody with these wheels do some measuring and maybe photographing for me?
I need to know the length of the centre hole (distance from front face to rear face), the diameter of the hole at both ends and if there is a taper on the inside lip.
If I could have photos of the inside of the wheel centre-from both sides-that would be very helpful.
Many thanks, David b
'65 S2 4844
PostPost by: dunclentdr » Tue Jan 31, 2017 9:05 pm
Hi David
Sounds like an interesting solution - I have a set of 6x13 revolutions which I'd like to adapt for either KO or bolt on 26R hubs - mine have an adaptor plate at the rear - is it the plate you are making to fit? If so I'd like some too!!!
David
img_7957.jpg and
img_7956.jpg and
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
dunclentdr
PostPost by: Davidb » Tue Jan 31, 2017 11:08 pm
Hi David, No I am not using a plate. I am fitting the Revolution wheels to "proper" four pin 26R hubs so I need the 26R wheel centre dimensions as above.
'65 S2 4844
PostPost by: Elan45 » Wed Feb 01, 2017 2:45 am
I'd be happy to help, but 900 miles from Ohio home and the wheels. Perhaps I can get my son to take some photos for you. PM your email to me and I'll try.
You do know the pins are on a 4in pin circle diameter?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: Davidb » Wed Feb 01, 2017 3:41 am
Roger, you have a pm.
The holes in the Revolution wheels are on a 3.75 pcd so what I am doing is re-drilling the hubs with the 3.75 holes at 90 degrees to the 4" holes so that the car can be fitted with either type of wheel.
I would like to get the dimensions of the inside of the 26R wheel centre so that I don't miss a subtle difference.
'65 S2 4844
