wheel spinners
starting to rebuild my plus 2 cant find out which hub and spinner I use. If the passengers side rotate anti clockwise I would have thought that the spinner rotates in that direction to tighten up the wheel. But have been told that its the other way round
- Cwollen
You are correct.
Left hand side is anticlockwise, RHS clockwise.
The way I remember it is to knock the spinner at the top towards the front of the car in the direction the car goes.
Well it works for me!
Eric in Burnley ( diff back in ready to go, but it`s raining)
1967 S3SE Type 45
PS. just thought of another one. Left hand side ---left hand thread.
1967 S3SE Type 45
- ericbushby
Sat in the car, driving!!
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
You can also remember that when you re-install the wheel you put it "back on" - rotate the spinner to the back of the car to tighten.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
Very recently bought a +2 which is half way through a restoration started by previous owner and noticed someone has assembled both axles wrongly, ie the spinners will tend to undo as the wheels rotates, worrying! Just as well I'm stripping everything prior to rebuild.
- Nic
Many hubs have a painted green or red segment (starboard / port) but I suppose if you don't your right from your left or you're colour blind, you're stuffed.
Also, all wheels tighten to the front, but if you don't know your front from your back......
- KevJ+2
Hubs and trunnions,
RH thread on RH side
LH thread on LH side
Doors
Out for open
In for closed...
Out for open
In for closed...
I visited New Zealand 2 years ago and went to at big expo at the Southwards Museum. There were 3 Lotus Elans in the carpark and one of them had fitted the hubs on the wrong side on his +2.
- alan.barker
I heard of that happening, Hubs installed wrong. Best to check that the spinner turns in the correct direction when starting the spinner on the hub threads. Don't forget to check both sides. Is the only way to tell if the hubs are installed right, would be by the threads?? Can the hubs even be installed wrong?
Sarto
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
