26R wheels and hubs...advice
Hi.
I'm looking to fit 26R wheels to my S4
Anything I should be aware of other than I need to change the spline hubs for the 4 stud affairs?
Are copy wheels available and are the 4 stud hubs available too?
Also are the hubs as easy to swap as would appear??
Many Thanks
Many Thanks
- viper
You can fit 26R wheels to an S4 in several ways:
1. Buy wheels with the same peg drive system as the S4 - Both TTR and Kelvedon lotus sell them in aluminium or magnesium. Downside is that spinners are not like the 26R ones and the standard peg drive is way inferior to the 26R ones.
2. Buy 26R front and rear hubs (S1 type at the rear), spinners, drive pegs, and wheels (mag or ally). All is a straight swap. Most authentic looking in my opinion, but most racers find it necessary to put some locking mechanism on the spinners.
3. Buy bolt on hubs front and rear and then the bolt on version of 26R wheels, in mag or ally. Most secure way of attaching the wheels, but not as attractive in some people's view.
Whatever you do, there are choices you can make as to 5 1/2" or 6" rims. You can also expect clearance problems on the rear wishbones and maybe interference on the wheel arches. (I assume that you have the smaller id springs already at the rear). All is sortable but not necessarily as straightforward as you might hope. I suggest you call Tony Thompson at TTR or Pat Thomas at Kelvedon for advice
Turning money into noise!
- toomspj
I bought the kelvedon 5 peg 6 x 13 alloy 26r wheels and these attach straight to standard knock on hubs. I bought alloy 26r spinners to suit. Very happy
Option 2 using the 4 peg drive seemed a realllly costly although perhaps a more correct way if doing it but I couldn't justify the cost
Gordon
26/5416
26/5416
- gordont
gordont wrote:I bought the kelvedon 5 peg 6 x 13 alloy 26r wheels and these attach straight to standard knock on hubs. I bought alloy 26r spinners to suit. Very happy
Hello Gordont, except from the look, are these alloy wheels lighter than the original steel ones?
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
I use 6" rims on my 26R bodied car with the Dunlop racing tyres. More relevantly, I used 5 1/2 on my road sports car (narrow bodied) with either 175/60x13 or 185/60x13 Yoko A048 tyres. It is tricky to get 185 tyre under a standard wheel arch (need to get the wheel offset just right and it's different for every car). In my opinion 175/60 tyres work best anyway.
There's more risk of the rim fouling the rear wishbones with 6" wheels but the trade off is that they probably give the best performance.
Good luck and expect to have to do some machining somewhere in the process!
Paul
Paul
- toomspj
Very nice....
