Refinish aluminum wheels w/oven cleaner
Has anyone refinished their aluminum wheels with oven cleaner on this board (see attached link)? I'm thinking about trying it on my Revolutions wheels. Thanks in advance.
http://www.924.org/techsection/wheel_refinishing.htm
- tmrlotus+2
I used oven cleaner to clean up an aluminum cased transmission. I figured if I screwed up, I could paint it. Actually, it worked great. The cleaner removed all the grime, old paint, dirt and corrosion, leaving a very shinny case. I did this a couple of years ago and the case still looks great, though a bit dusty. Never tired it on aluminum wheels. It did not seem to pit the aluminum, so I would guess it would not hurt the machine finished portion of the wheels. But, I would try it on the inside of the wheel on a very small area first. Years ago, I used Revolution wheels on a race car, but never tried to clean them with oven cleaner, just brake cleaner.
YMMV.
Rob Walker
26-4889
YMMV.
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:I used oven cleaner to clean up an aluminum cased transmission. I figured if I screwed up, I could paint it. Actually, it worked great. The cleaner removed all the grime, old paint, dirt and corrosion, leaving a very shinny case. I did this a couple of years ago and the case still looks great, though a bit dusty. Never tired it on aluminum wheels. It did not seem to pit the aluminum, so I would guess it would not hurt the machine finished portion of the wheels. But, I would try it on the inside of the wheel on a very small area first. Years ago, I used Revolution wheels on a race car, but never tried to clean them with oven cleaner, just brake cleaner.
YMMV.
Rob Walker
26-4889
Thanks Rob, I appreciate the feedback. I'll let you know if I have the courage to try it!
- tmrlotus+2
I use oven cleaner to strip paint from my plastic model kits and slot cars I restore. To this date it has never touched the plastic but is brilliant at getting old Humbrol paint off! I'd be surprised if it touched the Aluminium.
Good luck,
Pete
Good luck,
Pete
- Pete Shepherd
