Repaired steel wheels / refurb / Minilites
I just spent a couple of days wire brushing and priming my old steel wheels, luckily found an old Ikea sink as a wheel mask!
Anyway wheels as follows
No 1 - OK
No 2 - OK
No 3 - Peg holes slightly enlarged
No 4 - Rim welded + large dent
No 5 - Peg holes very enlarged
The question is what is acceptable, also I am going to be using TTR rear UJs , would alloys be better suited?
Any advice gratefully sought!
George (4th)
No 1 - OK
No 2 - OK
George (4th)
Guild member and proud of it
George4th - Second Gear
Before you do anything else, take them to a tyre place and see if they run true and are within balancing limits - if not you are wasting time.
Chances are that if it is welded or bent it is worse than you think - I've got a perfectly restored wheel that is egg shaped!
- AHM
George,
There are some wheel specialists who can straighten steel wheels if they are bent. The downside is further investment with no guarantee of success. I had my K/O wheels straightened many years ago. They were much easier to balance after that, but the wobble eventually returned. I replaced with panasports.
Dan
Dan
You can rebuild steel wheels, a friend rebushed the holes then replaced the outer rims with new ones which he bought from Germany, they are like new and are probably truer than original. Not a cheap way to go but still an option.
- AussieJohn
Thanks to all. The thing is I don't think my French tyre fitter tried particularly hard to balance the wheels. I think he only tried two and then gave up. His comment was that they would require a lot of weights mmmmmmmmmmmm So I don't think they are that bad.
Having said that we do want the car to be very usable so have ordered a set of Minilites from TTR.
My steel wheels will be sold in due course
George (4th)
George (4th)
