Minilite question
PostPost by: nebogipfel » Sat Jul 30, 2011 7:14 pm
The more observant among you will notice that I have been trying to find a better spare wheel for my car, mine being scrap :shock:
It looks like it's going to be a problem. ......
This set me thinking about alternatives and I have wondered about Minilites. My question is do any of you chaps know if 13x5 minilites with 155/80x13 tyres will fit inside standard S4 arches with standard springs? I'm thinking a half inch on the rim with standard tyres shouldn't make much difference; but what do I know?
I don't want to start bashing spring platforms or weakening the wheel arches :wink:
nebogipfel
PostPost by: jk952 » Mon Aug 01, 2011 12:29 am
Hi John,
I bought new minilites, 13x5 for a S2 elan, fitted 155x80x13 tires and they fit (posted elsewhere for someone), but they were very close to the standard spring mounts. Cleared the fenders, although it appears not by much! Note bolt on hubs not knock offs. Had to grind the susp. bolt heads to clear rim inner but this is normal for minilites. I imagine if the tires clear an S2 they should clear an S4 :? Offset for knock offs should be the same I presume... as the unused k/o hubs in the shed look to have the same flange location but I didn't measure them.
Jack
(ps: observant :D )
jk952
PostPost by: RedS4 » Mon Aug 01, 2011 4:07 am
While I can't comment on Minilites, I can confirm that steel 13x5's with 165/75's fit quite happily under S4 guards as that is what was on my S4 when I acquired it. :)
I have since replaced them, but it had nothing to do with fit or fouling... 8)
Evan J
Elan S4 FHC RHD 36/8569 AND White Evora S..
RedS4
PostPost by: nebogipfel » Mon Aug 01, 2011 9:03 am
Thanks for the replies chaps :wink:
Looks like they will be tight, but should fit .......... unless someone knows better of course?
I'd be somewhat miffed if I spent ?500 on a set and then couldn't use them :shock:
nebogipfel
