Series 2 Elan tyre size
PostPost by: casalunge » Thu May 05, 2011 7:17 pm
Can anyone out there please advise me as to the correct profile a 145/13 tyre should be for a type 26 series 2 elan?
Many thanks
Colin
1960 Lotus 18 FJ
1962 Lotus 22 FJ
casalunge
PostPost by: gordont » Thu May 05, 2011 10:38 pm
sorry no idea (I have 175/60/13) but guessing there are not many options other than 70 profile..... feel free to correct me though.
Gordon
26/5416
gordont
PostPost by: bcmc33 » Thu May 05, 2011 10:48 pm
The original tyres were 145/85 13.
I was told recently that 85 profile tyres are no longer made and the nearest is 80 profile.
You may find stockists that still have 85 profile, however.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: jk952 » Tue May 10, 2011 9:31 pm
Hello Colin,
For what it's worth; I just put on 155/80/13 on my S2, although a bit of a pedestrian tread design it is the only thing I could find (without importing?), they do fit, but note they are very close to the rear spring support (stock size springs, not the smaller spring units) and because of that I chose not to try a wider but lower aspect ratio. Besides, I kind of like the skinny tire look as per original. (on stock wheels) Note I am in n.a. 145's were not available.
Jack
jk952
PostPost by: jk952 » Tue Jun 28, 2011 12:54 pm
Colin, - update...
I recently purchased a set of new minilites, 5 inch width (can't get 4.5) and installed the same 155/80/13 tires as were on the stock wheels. The tires still clear, note however some material removal of the suspension bolt heads is required to clear the thicker rim of the aluminum wheel, which is common practice. (Mine are bolt on wheels.)
Jack
jk952
