Wheel Coating
PostPost by: Galwaylotus » Tue Mar 01, 2011 7:43 pm
The paint on my Lotus steel centre lock wheels is past its best. Two of them are badly weathered. As my tyres are old too I'm considering getting all of the wheels powder-coated and getting new tyres. Does anyone have any experience with powder-coated original wheels? Any cautions? I have two 4.5 inch and two 5.5 inch rims. Thanks for any input. :)
'67 S3 SE FHC
Galwaylotus
PostPost by: pereirac » Tue Mar 01, 2011 9:45 pm
I had my wheels bead blasted and powder coated in the late 1980s and they still look good!
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
http://www.lotuselan.co.uk
pereirac
PostPost by: alexblack13 » Tue Mar 01, 2011 11:49 pm
This was the last thing I did when finishing the Sprint resto. I had them carefully cleaned and blasted then instantly PC'd in satin black. I then kept a close eye on them for slackening off,checking after every run. I had a big torque wrench and the spinner tool in the boot for a while. They were always bl**dy tight! So much so I had difficulty getting the bu**ers off.
I'm more than happy with the powder coating. Cost me 120 GBP for all four.
Best of luck with your car.
Alex...
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: GrUmPyBoDgEr » Wed Mar 02, 2011 7:27 am
Some years ago I had my S4's original steel wheels blasted & powder coated by an experienced company in Reddich in the Midlands.
The proprietor advised me to put a bead of clear silicone all the way around the areas where the wheel centre attaches to the rim.
His explanation was that the blasting penetrates further than the powder coating & therefore corrosion could (will?) occur at that interface.
I thought that was very good advice :wink:
My wheels have been plastic bagged, kept dry & unused since then so I can't verify his advice with personal experience. :oops:
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: alexblack13 » Wed Mar 02, 2011 8:13 am
Hi Guys, John,
I was a bit worried about the thickness and durability of the coating where the spinner (nut) contacted the wheel. I was sure it would suffer to the point of being destroyed and allowing the wheel to slacken, but experience has not shown this so far. The car did about 3k mls last year with some good long runs and as I said I checked the wheels for security often at 1st then less regularly as confidence was restored.
Interesting point on the sealant thought John. Might have a look next time I take them off for cleaning.
Have fun guys.
Alex..
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: oldelanman » Wed Mar 02, 2011 9:25 am
Check the wheels aren't buckled before you spend money on refurbing them.
I had mine powder coated but found it didn't get into the gap between the centre and the rim so sealer is required to keep out the moisture and improve the appearance. The finish is also too brittle and tends to chip easily, the rim edge is particularly vulnerable when fitting tyres and balance weights. Also if it does get chipped you can't touch it up like paint. My experience may not be typical but if I did it again I would go for paint.
By the way.....J. D. Pelly you are the GrUmPyBoDgEr and I claim the ?5 prize :wink:
S4 DHC
PostPost by: GrUmPyBoDgEr » Wed Mar 02, 2011 9:35 am
oldelanman wrote:Check the wheels aren't buckled before you spend money on refurbing them.
Oh bugger, rumbled so soon :oops:
GrUmPyBoDgEr
PostPost by: Galwaylotus » Wed Mar 02, 2011 6:42 pm
GrUmPyBoDgEr wrote:Some years ago I had my S4's original steel wheels blasted & powder coated by an experienced company in Reddich in the Midlands.
My only concern about that is that most silicone sealant contains acetic acid and acid promotes rust. Perhaps another sealant would be better. :roll:
'67 S3 SE FHC
Galwaylotus
PostPost by: GrUmPyBoDgEr » Thu Mar 03, 2011 8:43 am
My onlcy concern about that is that most silicone sealant contains acetic acid and acid promotes rust. Perhaps another sealant would be better. :roll:
Maybe you've got a point there & maybe the man didn't say silicone but just sealant. :roll:
I've not done my wheels but will bear your comment in mind when I do.
GrUmPyBoDgEr
PostPost by: Galwaylotus » Fri Mar 04, 2011 10:20 pm
Thanks to all of you guys who replied. I was doing really well until I read Roger oldelanman's response and now I'm scratching my head again!! :? :? :roll:
'67 S3 SE FHC
Galwaylotus
