Bolt-On Wheel bearings
I've done quite a few searches and have come up short. the Cross reference on GG's parts cross reference indicates an Outer Cup Reference number of: Timken 03961 Cup - but the bearing shop here locally (whistler bearing - no affiliation) indicated that that's not a valid part number. does anyone have a valid part number for an outer Bolt-on wheel hub cup for a '65 Baby Elan?
the outer hub size accepts an O.D of a cup roughly @ 1.77"
btw - the Bearing / Cone that i'm using is: Timken 03062 Cone
tkx for your help
tkx for your help
- sonunet
This search
http://www.google.com/search?hl=en&q=tr ... =&gs_rfai=
got me this hit
http://catalog.brakewarehouse.com/ShopB ... ls&mode=PA
and the answer is
TIMKEN
03062 Cone $25.99
Front Wheel Brng;Front Whl,Outer ; 2 Per Veh; Years: 1965-1966;Qty Per Vehicle:2;
03162 Cup $12.99
Front Wheel Brng;Front Whl,Outer; Years: 1965-1966;Qty Per Vehicle:2;
07100S Cone $16.99
Front Wheel Brng;Front Whl,Inner ; 2 Per Veh; Years: 1965-1966;Qty Per Vehicle:2;
07210X Cup $6.99
Front Wheel Brng;Front Whl,Inner; Years: 1965-1966;Qty Per Vehicle:2;
Gary
got me this hit
and the answer is
TIMKEN
03062 Cone $25.99
03162 Cup $12.99
07100S Cone $16.99
07210X Cup $6.99
Gary
Noted and correct on the Golden Gate Lotus Club Cross Reference.
Please email any additions or updates to me at webguy"at"gglotus.org
Kiyoshi GGLC WebGuy
Kiyoshi GGLC WebGuy
Life is more fun behind the wheel of a Lotus!
www.gglotus.org
www.gglotus.org/blog
www.gglotus.org
khamai - Second Gear
I just measured my S1 bolt-on hub and it's ~1.6".
I also measured a Vitesse hub (also bolt-on, but using the larger stub axle, the same as the knock-ons) and the I.D. is ~1.8".
Is there any chance your hubs were replaced at any point?
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Call Dave Bean and talk with Tom Smith or Ken Gray. The number is 209 754-5802 and ask them.
If you have a 5/8 inch cone with the 3/4 inch race then you either have to read the part number from
the old race or find out what you have. The outer bearing you gave is the 5/8 inch cone, the outer
race diameter is the GT6 hub, it is also the knock off hub bearing diameter. Check that the inner
cone actually fits on the stub axle. I have GT6 uprights and stub axles on my S2 Elan. I didn't look up
the diameter of the bearings until after I posted my reply. take a look at the Dave Bean page below.
Also while talking with them order the Elan Catalog and the English Ford Racers Catalog too,
both catalogs has a lot of good info that you need to get things done on your Elan.
I'll email you a link that may be helpful.
all, thanks for all of your help. i think what i have are GT6 hubs ( which i got cleaned up and powder-coated ) - and the bolt-on (standard Spitfire) uprights. I'm in the process of exchanging out the K/O assembly to the Bolt-Ons. what i might do is disassemble the old K/O's that i have. Clean up the upright and stub axle; then mix and match using the K/O upright, stub axle meshed with the GT6 Hubs.
btw - in the process of a nut and bolt restore of a '65 - Type 26
s
s
- sonunet
The following combination should work fine:
- Elan knock-on upright and stub axle;
- GT6 bolt-on hub and bearing;
- Elan caliper bracket, disc/rotor and caliper (knock-on and bolt-on are the same)
The exact same combination was used on the Vitesse 1.6.
Paddy
Paddy
1963 Elan S1
S,
Your problem is that your Elan needs to grow up! None of us have "baby" Elans. I see your Elan is a Series 2, a much more descriptive term. Ugh Christoper Neal, see what you've started.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
