alloy rear hub carrier removal
PostPost by: yonner » Thu Feb 26, 2009 10:41 am
how do i remove the shock absorber from the rear hub?
yonner
New-tral
PostPost by: rgh0 » Thu Feb 26, 2009 11:03 am
I presume you have removed the rear strut / hub from the car. The top of the strut will have a cap that holds the shock inside the strut. This needs to be unscrewed to remove.
The top cap is screwed into the top of the strut and comes normally in one of three forms
1. A plain circular cap - grip with multi grips or pipe wrench to turn
2. A circular cap with a couple of notches in it - use C spanner
3. A hex protrusion in the top of cap - use suitable spanner (wrench)
Any of the three may have been locked by punching in the side of the strut near the top in a couple of locations. this may need drilling out to free up the cap for removal.
PostPost by: GrUmPyBoDgEr » Thu Feb 26, 2009 11:04 am
Normally no one attempts this.
The usual way to replace dampers is to unscrew the retainer in the top of the existing damper tube & then to fit a new damper insert into that tube.
If you do a search on here you willf find that the subject is well covered.
Removing the steel damper from th alloy hub casing will be extremely difficult, probably resulting in destroying one of or both of the components.
Good luck
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: GrUmPyBoDgEr » Thu Feb 26, 2009 11:08 am
That was a race against the clock Rohan :lol:
GrUmPyBoDgEr
PostPost by: yonner » Thu Feb 26, 2009 6:48 pm
im actualy selling the rear hubs as they are in good condition and i dont need them but before i sell anything i like to strip it right down and inspect it all so il just remove the damper and leave the tube in and give it a good clean up
cheers for the replies guys your time is much apreciated
yonner
New-tral
PostPost by: GrUmPyBoDgEr » Fri Feb 27, 2009 5:50 pm
Yonner,
the bills usually arrive one month before the end of the fiscal year.
Payment to be made within 28 working days!
:lol: :lol: :lol:
GrUmPyBoDgEr
PostPost by: yonner » Fri Feb 27, 2009 6:47 pm
cheqe or paypal :P
yonner
New-tral
