Lower Arm Fouling Rim.
PostPost by: Over Steer » Wed Jun 04, 2008 3:36 pm
Hi Everyone.
I've just fitted a new set of alloys to my '69 +2 from Matty's. these are fitted with 175-70s. the suspension set up is standard using GAZ struts. however the lower A frame arm is fouling the rim on both sides.
the original steel rims leave approx 5mm clearance.
is this simply the fact that alloys have to be casted thicker? or is it down to work done to poor tolerances?
i can grind 2mm off the point of contact to make the arm clear but this is not the ideal solution.
Any clues?
Elan+2 rim.jpg and
Jan
1963 23B
1969 Elan + 2
1973 Europa JPS Special
2004 Prep'ed Lotus Exige
Over Steer
PostPost by: bcmc33 » Wed Jun 04, 2008 4:23 pm
Grinding the corner of the arms is the only fix. Well documented in this forum. Do a search and you will find some pictures that will give you a good idea of what is required.
I'm sure Matty will send you a sketch of exactly what to do.
I seem to remember seeing arms at TTR with the corners already removed.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: CBUEB1771 » Wed Jun 04, 2008 4:39 pm
bcmc33 wrote:Grinding the corner of the arms is the only fix.
Actually it is the only fast and inexpensive fix. Spyder makes replacement arms for the Elan and +2 with camber adjustable by spherical rod ends at the outboard ends. These arms provide much more clearance to the wheel. The thickness of the alloy rim is the root of the problem.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: Over Steer » Wed Jun 04, 2008 5:32 pm
AHHGHH there goes the galvanizing... at least it's an easy fix.
Jan
1963 23B
1969 Elan + 2
Over Steer
PostPost by: bill308 » Wed Jun 04, 2008 11:14 pm
The first time I put Panasport alloys on my car, I backed out of the garage to go for a run. The corner of the outboard retaining bolt head machined a groove on the inside of the wheel. Careful clocking of the hex head provided enough clearance to eliminate the problem.
Bill
bill308
