US Alloy Wheel Options
PostPost by: collins_dan » Wed Apr 09, 2008 5:20 pm
I am thinking about changing to alloy wheels. On my S4, I am currently running 185/60/13's on original knock-on wheels and fenders. In making this change, I was thinking about moving up to 14" or 15" wheels in order to give myself more tire options. I have recently received pricing quotes from Superlite (13x5.5 $285, 13x6 $290, 14x6 $295, 15x6 $310) Minilite (14x5.5 or 6 $326) and Panasport (13x5 $270). My first question is will any of these 14" or 15" options fit without flaring the fenders? If not, will 185/60's fit on the 13x5 panasports, it mentions that 155 or 165 is the max on RD Enterprises' website? Thanks. Dan
collins_dan
PostPost by: aussieelan » Wed Apr 09, 2008 11:07 pm
I am currently investigating options for my +2 in regards to 14" wheels. This site has proved very handy to work out finished sizes.
Hope it helps you to.
aussieelan
First Gear
First Gear
PostPost by: msd1107 » Thu Apr 10, 2008 7:42 pm
aussieelan,
The Miata site shows everything correctly except for the tire revs/mile. To see this, enter a tire size and see the tire revs/mile. Then go to www.tirerack.com, enter the same tire size, go to one of the manufacturers, look at the technical data that usually has the manufacturers tire revs/mile figure. There will be a difference.
Quite fortunately, the percentage difference between two tire sizes is correct since the ratio of the two incorrect figures is correct.
If you really want to be assaulted with too much data, I have a spreadsheet that has the commercially available tire sizes sorted by revs/mile so that if you enter one figure, you see all the sizes and how far apart they are. It is much too large to post, but if you PM me, I will send you a copy. There is one column of the sheet that is identical to the Miata figures, but this is never used since it is a purely geometric calculation, and the manufacturer reported data is used for all speed calculations.
collins_dan.
The quote you got from Superlite is probably for their Classic Range. The weight for a 15X6 wheel is about 18.8 lbs. Minilite quote about 20 lbs for their 15X6. The stock wheel is about 12.5 lbs, so this is a consideration. Superlite has lighter wheels, still in the minilite style, in the Ultralite and cast center series, about 14.8 lbs for a 15X6, but they are pricier. The billet series does not have a minilite style but weighs 13 lbs. And finally, they have magnesium wheels in the old 26R pattern.
As to whether they will fit, it depends on which 185/60-13 tire you have. I have run 165-13, 185/70-13, and 185/60-13 on my early S4. They all required material removal from the inner rear fenders, and, eventually, small rear springs. The 185/60-14 is the same diameter as the 155-13. The 185/55-15 is between the 155-13 and 165-13 in diameter.
Hope this helps.
David
1968 36/7988
msd1107
PostPost by: garyeanderson » Thu Apr 10, 2008 9:28 pm
I think Spyder is the only ones making a 14 inch wheel for the Knock-ons, I have not heard of any 15's for knock-ons yet. I can't help with tires on the Plus 2 but the arches look pretty large compaired to the S1 through S3 arches, S4's are slightly larger but still are tiny. There are games that can be played with off-sets and smaller springs. You can probably relocate a portion of the inside arch if you want to go wild on the Plus 2 if thats where your clearance ends up being non-existant. Take a look at Georges (cabc26b) work on his S2 26r.
Larger photos are over
http://www.lotuselan.net/forums/viewtop ... ght=#79623
garyeanderson
PostPost by: msd1107 » Thu Apr 10, 2008 9:51 pm
No need to get the whole spreadsheet.
I extracted two sheets of tire data so you can see what is close and how close to any tire size.
David
1968 36/7988
20040227 Tires.xls
Tire sizes vs rev/mile sorted by both wheel size and rev/mile.
(986 KiB) Downloaded 708 times
msd1107
