Wheels ??
PostPost by: purplepete » Thu Jan 31, 2008 10:07 am
could someone tell me exactly what these wheels are called??
It has been suggested that theyre dunlop D1's??
definately on an elan.
thanks in anticipation!!
[img][img]http://i222.photobucket.com/albums/dd21/purplepete13/1201714539241.jpg[/img][/img]
purplepete
First Gear
First Gear
PostPost by: rgh0 » Thu Jan 31, 2008 10:31 am
I have always heard them referred to a Lotus spider style alloy wheels. Dont know if they have a proper name
PostPost by: stuartgb100 » Thu Jan 31, 2008 1:38 pm
They look similar/maybe same as the rims fitted to the Ford Cortina MkII
1600E (albeit spinnered not bolt on).
Can't remember the darned name though.
Stuart.
stuartgb100
PostPost by: GrUmPyBoDgEr » Thu Jan 31, 2008 1:43 pm
Stuart,
I believe you're thinking of the "Rostyle" wheels of the period.
They were however pressed steel.
I think Rohan's hit the nail on the head.
That wheel & tyre look a bit beyond saving though.
I've seen those wheels for sale new at Paul Matty.
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: ppnelan » Thu Jan 31, 2008 7:18 pm
"Lotus Brand Alloy Wheels". :)
:arrow: Matthew
ppnelan
PostPost by: Lincoln62 » Fri Feb 01, 2008 1:14 am
They look like Dunlop mags. I have seen many +2's and Europas with these wheels. It is likely they were an option.
A friend has recently bought a new set for his +2. I like 'em.
Peter
66S2
Lincoln62
PostPost by: handi_andi » Fri Feb 01, 2008 1:24 pm
I would have to agree with Peter. Those are the nicest alloys I have ever seen fitted to an Elan and would love to see what they looked like after a trip to a good Alloy wheel refurb specialist.
Andy
handi_andi
PostPost by: handi_andi » Fri Feb 01, 2008 1:26 pm
Just checked out Paul Matty's website and it appears those wheels are on special offer at the moment:
Knock on Alloy
Paul Matty P/N: WGRWH050C
51/2" x 13" Knock on Alloy wheel
RRP - ?96.00 *
Special Price - ?94.08 *
* all prices are excluding UK VAT @ 17.5%
Would like to point out I am nothing to do with the company, was just curious as I wouldn't mind a set myself.
Are those the same size as the standard Colin Chapman special steel wheels?
Andy
handi_andi
PostPost by: GrUmPyBoDgEr » Fri Feb 01, 2008 1:33 pm
No they are 5 1/2 J x 13. Original Elan steel wheels are 4 1/2J x 13
They will fit however; the 70's race boys favour them on their Elans. They are a very tight fit around the rear outer lower wishbone bolts. The hexagon heads normally need the attention of an angle grinder or file.
GrUmPyBoDgEr
PostPost by: msd1107 » Sat Feb 02, 2008 3:08 am
Very true about the tightness of fit.
Use as thin a bolt head as you can, and use a 6 pt socket when removing to keep from rounding the heads.
The improvement in handling is worth it though. This allows you to run 165-13 instead of the standard 155-13 (or 185/70-13, 185/60-13) and use 28/33 tire pressures. The steering is more precise and the handling limits noticably higher.
David
1968 36/7988
msd1107
