Tyres Again!!
I have heard a few rumblings about Yokohama doing a sticky 165/80 x 13 tyre.I have scanned the archives on here and cant find a reference and have given up searching various suppliers sites on line. Does any body know if this Yoko exists and what type it is? Else I'll be going for 185/70 A021R's and taking a mallet to the spring pans!
I cant help feeling that the 185's are too grippy and wonder what they'll be like in the wet?
- tower of strength
Look at this site
http://www.intech-competition.com/perso-27917.htm
No 165/80-13 tires there. For that, Michelin XAS FF seems to be the solution.
http://www.longstonetyres.co.uk/radial.php
The availability of high performance tires for 13 inch wheels is a problem. If you are willing to put up with dodgy wet handling and reduced tire life, you could look for DOT tires with a tread wear rating of 60 (not 40), but 80 series tires are close to non-existant. For DOT tires, probably you are looking at 185/60-13 which are smaller in diameter than the standard 80 series tires.
Good luck
David
1968 36/7988
Good luck
David
1968 36/7988
msd1107 - Fourth Gear
Thanks David, I refuse to run Michellins, a personal issue!! I detest the thought of Jap tyres as well but I rekon it'll be Yoko's!, the lesser of two evils , just need to findf a cheap supplier
- tower of strength
Mark,
If you would rather not have Yokohama tires, you could try an English brand.
Avon cr6xx (along with Vredestein) at
or Dunlops at
http://www.dunloptyres.cz/en03.html
(Why are there not more vendors of English tires in the UK?)
There are some specialist producers of bias ply tires also, for the ultimate in vintage look and feel.
Unfortunately, except for the Yokohamas, tire prices tend to make you think twice or more. However, I believe in gulping twice and paying the price for the performance. 10,000 miles later, you will have forgotten the hurt on your pocket book, but still getting the benefits of the higher performance.
Don't forget that if you go for a modern sticky tire, that there will be more problems with oil pressure loss in corners. Depending on your driving style, you may have to go to a baffled sump, swinging oil pickup, or even dry sump.
David
1968 36/7988
or Dunlops at
David
1968 36/7988
The Dunlop brand is now owned by various companies in various regions of the world and many of the modern high performance Dunlop tyres are actually made by Sumitomo Rubber who own the brand in Japan and much of Asia.
Most of the historic racing Dunlop tyres are made in England by whoever owns the brand their, not sure who it is but there factories are old and tired and the volumes made small which is why they cost so much.
In Australia the Dunlop brand is owned by Goodyear and Dunlop tyres made by the Goodyear tyre factory. The various Dunop brand owners swap tyres around the world as they need to offer the full range.
The new Yokoham's are called A drive and they do most sizes but not 165/80 x 13 they are ?25+vat and are very sticky.
Maybe 175/70/R13s in them ?
Chris Hewett has some you could ask him what he thinks to them ?
http://www.demon-tweeks.co.uk/products/ ... 557013AA01
Matt
Matt
1967 Elan S3
1970 Elan S4 Sprint
1972 Europa TC
1973 Elan +2 s130/5
1978 Esprit S1
1981 Esprit S2.2
1970 Elan S4 Sprint
1972 Europa TC
1973 Elan +2 s130/5
1978 Esprit S1
1981 Esprit S2.2
- Matt
Thanks Matt,
on doing some research of other tyre manufacturers sites, 175/70 and 185/70 have the same rolling radius, so 175's could be the answer.
- tower of strength
I guess you're talking about the Plus 2. Doesn't have to be expensive, take a look at Toyo tyres, for instance for my plus 0, I can get Toyo type 350 or 330 tyres 165/70s at 38 Euros (25GBP) here in Germany. They even do a H rated 600-F8 series if you need this rating. (Haven't tried 'em, still running Michelins).
http://www.toyo.de/do/de/PKWSommer.asp?typ=350
http://www.toyo.de/do/de/PKWSommer.asp?typ=330
http://www.toyo.de/do/de/PKWSommer.asp?typ=600-F8
Gordon
Gordon
freddy22112211 - Second Gear
Gordon,
Be careful with the tire sizes selected.
165/70-13 is 942 rev/mile. The standard 155-13 is 912 rev/mile, a noticable difference.
If you have a +2, the standard tire is 165-13 which is 887 rev/mile. 185/70-13 at 893 rev/mile is the closest to that.
To illustrate, at 6500 rpm and with a 3.77 differential ratio, 165/70-13 gives 110 mph, 155-13 gives 114, 165-13 gives 117, and 185/70-13 gives 116. (If you remember, a couple of different road testers got 7000+ rpm with a 3.55 diff and 155-13 tires - close to 130 mph. And this was 40 years ago.)
Or to put it in different terms, at 60 mph, you go from 3344 rpm with 165-13 to 3551 rpm with 165/70-13.
Some people care, some don't. I use a spreadsheet that shows all these figures. Ask me for a copy (david_harralson at hotmail.com) so you can do your own research.
David
1968 36/7988
David
1968 36/7988
Mark,
I have done about 500 miles on my yokohama A drives and am very impressed. The handling is vastly improved and I get no tyre squeel. I have 175/70s and they rubbed the spring perches until I altered them with a club hammer. The speedo reads high now.
- chrishewett
David,
I'm not sure if I remember a difference when going from the 155/80s to the 165/70s, might have been slightly better acceleration (except for the vastly improved cornering of course). It's not very much anyway. Didn't lose any top speed because I have the 5 speed box.
Gordon
David,
Gordon
205's are too wide for 5 1/2" standard rims, 175 and 185s foul the lower rear spring platform, this needs adjusting (twatting with a lump hammer seems to be the general concensus) to prevent them rubbing. 205's are huge! I think you will have some real issues using them, I think you need to find a Capri 2.8I owner that needs some new boots!
Good luck
Good luck
- tower of strength
Bizzare!!! post some pics, never seen 225/45 13s, the holy grail in the capri world were 235/50 x 13 for the rear of x pack cars.
- tower of strength
