Rear wheel bearing
Does anyone have a non Lotus part # for the inner rear wheel bearing early style. I thought it was from the 60's Cortina. NAPA got me a bearing that is an SKF BR88506 bearing. The id. & od. plus the oa thickness of the inner race are correct but the thickness of the outer race is only about 2/3 the original,so the inner race protrudes both sides instead of only one side.
Keith Marshall
- saildrive2001
I had a seniors moment & asked about the wrong bearing. Because of an accident many years ago, when it was repaired they used an early style housing on the left side & I have the original late style on the right hand side. What I wanted was the part # for the late style inner bearing which is wider than the outer bearing. As I said in my first post the one I got was narrower in the outer race. Can anyone help?
Keith Marshall
- saildrive2001
Keith,
According to my records:
REAR WHEEL BEARING
Inner SKF 361964 (Susan Miller) or 411546 (TTR)
or 411546 (Paul Matty)
Outer SKF 6206.2RS1 (Susan Miller) or NSK 6206DDU (TTR)
or FAG 6206.2RSR.C3 (Paul Matty)
Please double check these reference numbers first, before ordering.
Stuart.
REAR WHEEL BEARING
Stuart.
- stuartgb100
Keith,
REAR WHEEL BEARING
Stuart.
REAR WHEEL BEARING
Stuart.
- stuartgb100
