Help me identify a steel wheel please
PostPost by: Hawksfield » Mon Mar 14, 2022 1:48 pm
Hi Mike
a quick photo if ti helps
The image you show is different to my wheels
the centre pressing is not the same
The rim is not the same
sorry about the orientation
wheel1.jpg and
+2s130 1971
PostPost by: tonyabacus » Tue Mar 15, 2022 12:01 am
Hello Mike
One way to see if the centre has been flipped in the outer is to look at the beads on the inside, usually the outer bead is flat and narrow, the inner bead is a gentle curve to the outer edge of the rim and wider than the bead on the outer edge. On an Elan, if the wheel is flipped this would give the wheel quite a dished look when fitted to the car and contrary to the pictures already shown.
To check the backspace of what you have, take a piece of timber to fit across the centre of the wheel and resting on each outer edge of the rim, now measure through the centre hole from the timber to the centre hole. You can do this on both sides of the wheel and then compare with the other wheels you have. This will show you what inset you have when the wheel is mounted on the car and perhaps enable you to match up all four rims.
This link below may be helpful where it shows front space and back space
https://encrypted-tbn0.gstatic.com/imag ... w&usqp=CAU
tonyabacus
PostPost by: bitsobrits » Tue Mar 15, 2022 1:52 am
Hawksfield wrote:Hi Mike
That wheel does not appear to be standard, as it appears the wheel center is standing too proud, i.e. a negative rim offset.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: tonyabacus » Wed Mar 16, 2022 12:02 am
Having had a second look at the photos you posted, can you confirm whether the wheel has had a band installed in the centre. There appears to be what look like two welds going around the centre of the wheel roughly an inch apart, can you confirm what I am looking at.
If you look at the topic about bent wheels posted a couple of days ago you will see Eric has posted a photograph of a wheel he was straightening on a jig. Around the centre you can make out the rivets that hold the outer and centre together, which looks different from what I can make out on yours.
Tony
tonyabacus
Previous
