14 inch tyres and gearing.
PostPost by: billmoore42 » Sun Nov 29, 2020 4:27 pm
TBG: Thanks for the reply. I am slowing building up my nerve to do this.
1967 Lotus Elan FHC Spyder Chassis
1972 MGB (since 1975)
billmoore42
PostPost by: TBG » Sun Nov 29, 2020 6:03 pm
Bill - I don't know if you have seen this - the speeds versus rpm with a 3:1 cwp?
May help you make up your mind and it is exactly what I have now. 2nd gear is a hoot!
CWP gearing.jpg and
TBG
PostPost by: billmoore42 » Tue Dec 01, 2020 4:50 am
TBG:
Wow, it looks like 67 mph at 3000 rpm, and 80 MPH at 3500 rpm with a 3.1 differential. This would be a delight, as currently I hate taking the car on the freeway with its 70 MPH + traffic here in California for any length of time.
It looks like I might be looking into getting rid of the rotoflex at the same time, as the work is all in the same area, and why waste my or the shops labor. I replaced the rotoflex couplings a couple years ago, and found it an trying task I may not want to do again. I will talk to the rear end shop that says they have some Lotus experience, and go from there.
billmoore42
PostPost by: TBG » Tue Dec 01, 2020 9:18 am
Bill - you won't be disappointed! The chart is a bit furry and 80 is actually about 3700 in my car, but still a vast improvement. I have not regretted having the CWP made by the delightful Gordon for one moment though. I did have my doubts reading stuff on here from the unbelievers but it was all tosh in the end!! Good luck and let me know how you get on. D
TBG
PostPost by: 1owner69Elan » Tue Dec 01, 2020 9:48 pm
Bill Moore:
As I believe you are using "standard" size tires (155/80r13) the gearing on your car with a 3.0 diff will be a bit taller than TBG's (1.65/70r13).
Here are the curves if you fit the 3.0 diff with those tires.
30Diffsemi155.jpg and
Attached pdf is less fuzzy.
30Diffsemiclose155.pdf
(200.23 KiB) Downloaded 249 times
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: TBG » Tue Dec 01, 2020 10:28 pm
Surely smaller tyres will give lower ratios.........?
TBG
PostPost by: 1owner69Elan » Tue Dec 01, 2020 11:22 pm
Smaller in width but taller with the 80 profile. (plus ~0.7 inches).
This taller 155/80 tire (while narrower) results in taller gearing. It is the height, not width, that governs this.
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: billmoore42 » Fri Dec 04, 2020 3:38 am
Thanks everybody for the suggestions. It looks like with my Michelin XAS tires in 155 by 13, I should get around 67 miles per hour at 3000 rpm.
billmoore42
PostPost by: 1owner69Elan » Fri Dec 04, 2020 3:54 am
As opposed to ~54 mph @3000 with your 3.77
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: billmoore42 » Tue Dec 08, 2020 4:59 am
Yes, about 54 mph at 3000 revs. One thing I am realizing is that the Semi Close ratio gear box, with its 2.97 first gear ratio, would be more suitable for this conversion than the earlier close ratio gear box with its 2.51 first gear ratio.
Having a 67 Elan FHC, I am assuming I have the Semi Close ratio box.
billmoore42
PostPost by: elans3 » Tue Dec 08, 2020 11:33 am
Not necessarily. My '68 DHC S/E was specified from new with the close ratio 2.5 : 1 and 3.55 diff, box and still has them, although the semi-close was much more prevalent.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
PostPost by: billmoore42 » Tue Dec 08, 2020 9:04 pm
Elan3:
Thanks for this, it looks like I will be trying to figure out my cars first gear ratio before anything else happens. The guy at the local differential shop, who has done quite a few British Cars, is hesitant on this one, as he thinks a 3.0 is for V8's.
billmoore42
PostPost by: TBG » Wed Dec 09, 2020 8:55 am
"as he thinks a 3.0 is for V8's."
Send him over here Bill and I will show him he is wrong!! :shock: :shock:
TBG
PostPost by: rgh0 » Wed Dec 09, 2020 10:25 am
TBG wrote:"as he thinks a 3.0 is for V8's."
to many variables for such a simple statement
i.e.
wheel and tyre size
first gear ratio
intermediate gear spacing
car weight
engine torque characteristics
In an Elan all of these can add up to make a 4 speed with a 3:1 diff ratio eminently practical where relaxed high speed cruising is most important compared to the other end of the scale of stop light drag racing performance :D
PostPost by: TBG » Wed Dec 09, 2020 11:32 am
True Rohan if drag racing is your thing, but what has happened to me is that 2nd gear is now blistering in acceleration and don't even talk about 1st!! :D
TBG
PreviousNext
