Plus 2 tire pressure
JJ66 wrote:Is the exploded view from a 3000M/Taimar? I haven't seen that kind of adjuster before, the ones on the later TVR's were a RH/LH thread close to the pivot point. I can;t quite work out what item 1 is in the view attached. Cheers, Jonathan
Its (allegedly) off a Cerbera. Here is a page of most of the bits. I'm still not sure how it works! I can only assume that the tube in the wishbone is threaded. My idea was to have a similar adjusted at the other end so you could tweak camber as well.
https://tvr-parts.com/tvr-parts/part-de ... e-adjuster
Now I had better vanish before the thread police start knocking.
- vincereynard
