Current thinking on 13" tires for S1-S2 Elans (2016)
• Page 2 of 3 • 1, 2, 3
bill308 wrote:Meg,
155 was specified for my 1966 S2 SE and probably for the following S3 SE's.
Bill
I stand corrected, Bill; I was quoting from the Workshop Manual which covers the S4 too.
Sandy, some of us drive standard Elans on public roads at proper Elan speeds and I, personally, haven't found problems with any tyres in the dry. I don't push cars in the wet, there isn't enough margin.
Meg
"some of us drive standard Elans on public roads at proper Elan speed"
I wonder what Colin Chapman and Jim Clarke would have considered proper Elan speeds
But I know they would have fitted Yoko A-050R for that quick trip back to Duns by Jim if they were available in the day
rgh0 wrote:But I know they would have fitted Yoko A-050R for that quick trip back to Duns by Jim if they were available in the
last I heard from my tire supplier, A050 were not available in Europe in 13" unfortunately (or 14") ...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
nmauduit wrote:rgh0 wrote:But I know they would have fitted Yoko A-050R for that quick trip back to Duns by Jim if they were available in the
Europe has had new noise regulations recently around tyres that have potentially stopped the release of the A 050R and they have kept supply of the A048R to there based on some earlier approval. In Australia you can no longer get the A 048R just the A 050R which appear to perform slightly better on the track.
The current Toyo 888R which was a similalry performing tyre to the A-048R has been replaced in Australia with a new version that meets the European noise regulations and it is slower on the track So Toyo users are moving to Yokos. I have heard rumours that Yoko are working on a new version also to meet the European regs which will probably also be slower
rgh0 wrote:nmauduit wrote:rgh0 wrote:But I know they would have fitted Yoko A-050R for that quick trip back to Duns by Jim if they were available in the
A048 is elan sizes were heavily de stoked here earlier this year, and supply has run out within a 50 km radius just as I was getting a set. I have heard that a Korean sub brand may take over Yokohama's A048 line, possibly by the end of the year, but have not seen any announcement long that line...
Regarding regulations, when I drive on A048, the noise is not coming from the tires...
S4SE 36/8198
nomad wrote:Like Ross, I'm a simple man....even simpler!
Last 155/80's are Douglas from Walmart. Made in the USA by Cooper I've been told. $28 a pop!! I like them and see only one flaw in them.......they came from Walmart!
Kurt
You let those Walmart clowns touch your Elan?
Fred Talmadge - Third Gear
Fred Talmadge wrote:nomad wrote:Like Ross, I'm a simple man....even simpler!
Kurt
Heavens no!! Purchased for an Sprite and I mounted them myself. [wire wheels]
Kurt.
- nomad
el-saturn wrote:................what surprises me: NOBODY mentions a modern tyre which can handle the power of a TC. in my opinion the tyres mentioned are adequate for vehicles for the disabled (i know and love my diabled friends btw!!): 30 to 60hp!!! and not 110 - 160!! i use a539 yokos 175 60 13 and 008s! sandy PS hope to get some critical replies
The standard Elan TC was rated at a 125 bhp or less depending on the model. In the '60s most engines were rated for gross power. Most of today's small to medium sized cars are rated at over 100 bhp net. In addition the Elan has a mass slightly more than half that of a modern small car. The 13-inch tyres from any reputable brand (Continental, Uniroyal, Goodyear, Bridgestone, Firestone, Dunlop, etc., etc., etc.) are more than adequate for a normal Elan.
'67 S3 SE FHC
'67 S3 SE FHC
Galwaylotus wrote:. The 13-inch tyres from any reputable brand (Continental, Uniroyal, Goodyear, Bridgestone, Firestone, Dunlop, etc., etc., etc.) are more than adequate for a normal Elan.
What is "adequate" even for a "normal" Elan is a very personal judgement and will be based on the drivers expectation and judgement with regards the usage and conditions in which that usage occurs.
Most modern 13 inch tyres ( even the cheapest) are far better than what was fitted to Elans in the day so they should be adequate . However expectations have changed dramatically over the last 50 years also so adequacy may not be what it used to be
Agreed, Rohan. I was referring to the comment about tyres capability of handling the power of a Twin Cam.
'67 S3 SE FHC
'67 S3 SE FHC
The problem I have with most 13" tires today is, they were designed for go to market lumps. The load carrying capacity of a single tire is almost equal to the total weight of the Elan. Would love to find a nice light weight tire, rather than adding the equivalent of 20 lbs to my flywheel.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
