Rear Wheel Bearings
PostPost by: George4th » Sun Sep 02, 2012 11:12 am
I gave up on the slide hammer as its quite small, I don't think it would have done anything.
....But the good news is the heat and socket trick worked and they are cleanly out!
Ho0oray for the internet!
All the very best and thanks again
George 4th (Terry to you)
Guild member and proud of it
George4th
PostPost by: stugilmour » Sun Sep 02, 2012 2:40 pm
Rohan Terry, et al
Thanks for the info. Will pass on some tips (particularly heat and the special tools) next week to my mechanic, as we are just ready to try and re & re the bearings with a press and the hub carriers out of the car. I expect I damaged one outside bearing in my earlier attempt as it only lasted about 10,000 miles to total failure.
Stu
1969 Plus 2 Federal LHD
PostPost by: George4th » Wed Sep 05, 2012 2:56 pm
One side done! .... and I used a small hammer!
Little taps are the key.
Thanks so much, just have to work myself up to do the other side.
(One little tip for us novices as I very very slightly burred the upper part of the thread on the axle due to the socket moving (when driving it out). Nut still works!
When I do the next one I will wrap in tape and then push the socket on so it doesn't move.
George 4th (!)
Stu
The tools work perfect!
George 4th (!)
George4th
PostPost by: George4th » Thu Sep 06, 2012 1:42 pm
2nd one done , hubs on and torqued!
Thanks Rohan
George 4th (!!!!)
George4th
PostPost by: rgh0 » Fri Sep 07, 2012 7:48 am
:D - glad it went smoothly
Previous
