Tire Pressure with 175/70 13 ?
khamai wrote:175/70-13 tires can be squeezed onto a 4.5" wheel, but 5.0 or 5.5 would be better. Some flaring would be needed at both front & rear.
Kiyoshi
My 175/70s are mounted on stock steel wheels, and actully don't appear abnormal.
I also didn't find a need for any flaring. Lucky, I guess.
Jim
Temporarily Elan-less
summerinmaine - Third Gear
As for pressures, I would start with around 26 psi for all four and possible go as low as 22 or 23 psi. I suggest starting at say 28 psi and chalking the shoulders of the tires and get on a skid pad (round-a-bout?) and see how much the tire is rolling over. Continue lowering the pressure in 2 lb increments until you see the tires rolling over. Then bump the pressure back up in 1 psi increments until you see the correct amount of roll over.
Kiyoshi
And for most of us on this side of the pond, make sure you have plenty of oil in the sump before starting your "skidpad" work!!
'67 S3 SE FHC
'67 S3 SE FHC
summerinmaine wrote:khamai wrote:175/70-13 tires can be squeezed onto a 4.5" wheel, but 5.0 or 5.5 would be better. Some flaring would be needed at both front & rear.
Kiyoshi
175/70s will fit under a S4/Sprint with minor rubbing at the front under full lock with the correct offset wheels (may foul with the spring perch at the rear with stock wheels). I believe the poster mentioned he had these under an S1. Both the S1 & S2 are, shall we say, "fender well challenged".
Here's a link to an article I wrote for the Golden Gate Lotus Club - http://gglotus.org/ggtech/elan-panasport/elanwhls.htm. At the time I had an S4 and wanted alloy K/Os. I'm now running a set on my S2.
Kiyoshi
Life is more fun behind the wheel of a Lotus!
www.gglotus.org
www.gglotus.org/blog
www.gglotus.org
khamai - Second Gear
