Steering wheel center cap
PostPost by: prezoom » Mon Dec 09, 2024 4:27 pm
Simple question for an overly cautious mind. I have a need to remove the steering wheel from my 1972 Plus2. The manual says too pry the horn cap off to remove. Have applied medium pressure to the point of deforming the plastic to no avail, but I am cautious of applying more pressure for fear of damaging the cap. Any help here would be gratuitously accepted.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: Hawksfield » Mon Dec 09, 2024 6:29 pm
Try prizing fron more than one point 180 degrees apart.
It will come off.
Good luck
+2s130 1971
PostPost by: 512BB » Tue Dec 10, 2024 8:14 am
Which wheel and horn push is fitted to your car? Makes a difference to how they are removed.
Post a picture Rob.
Leslie
PostPost by: prezoom » Tue Dec 10, 2024 3:23 pm
Leslie,
I wish I could post a picture however, being firmly mired in yestertech, my old cell phone is not compatible with my computer as it has a rotary dial and a crank on the side. I believe I could describe the horn cap as large in diameter as shown in the worshop manual. The car was the last Plus2 imported to the US.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
prezoom
PostPost by: pharriso » Tue Dec 10, 2024 4:07 pm
I think we are talking about this style of Badge:
IMG_7122.jpg and
The badge should be just a push fit onto the later style Horn Push:
0260K_SteeringWheel.JPG and
This is a Sprint wheel, but the horn push assembly is the same.
The badge should just prise off, the assembly looks like this:
LateStyle_HornBadge.jpg and
HornBadge_Off.jpg and
And for those of you that are interested, here is the whole later style horn push system modelled:
HornPushExploded_Assy.jpg and
When I have the time I was planning on adding a fault finding / solution posting... :roll:
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: RichardHawkins » Tue Dec 10, 2024 5:39 pm
Phil,
A bit of topic creep, what is that round thing in your door? Shown just to the left of your steering wheel.
Richard Hawkins
RichardHawkins
PostPost by: pharriso » Tue Dec 10, 2024 6:00 pm
RichardHawkins wrote:Phil,
Richard Hawkins
It's a tweeter (small speaker). My car was renovated by a music producer on Vancouver Island & has a high end stereo system (that I rarely turn on.)
Phil Harrison
PostPost by: lotusfan » Tue Dec 10, 2024 6:29 pm
A bit more of topic creep,
Phil
One might also ask what that strange thing is on the dashboard between the rev counter and the fuel gauge?
72 Sprint DHC
lotusfan
PostPost by: pharriso » Tue Dec 10, 2024 7:16 pm
lotusfan wrote:A bit more of topic creep,
Phil
We really are creeping... It's a microphone for my telephone (connected to the radio by cable & to my 'phone by Bluetooth). I can use my telephone hands free...
My car has a column mounted ignition lock so I used the hole in the dash where the ignition lock was mounted on earlier cars to mount the mic.
Hope the OP has the info they were after...
Phil Harrison
PostPost by: prezoom » Wed Dec 11, 2024 4:51 pm
Thanks Phil,
I initially thought it would be like my S2, but could not find a seam between the horn push and the base. Did not want to start jamming sharp objects to try to find the seam and make a mess of the thing. First step will be to find a pair of "cheaters", as it seems my bifocals are not up to the task. Subtile hint it is time to get my eyes examined again. Getting old............sigh.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
prezoom
PostPost by: andyelan » Wed Dec 11, 2024 6:30 pm
Hi There
Try using your finger nails to get behind the badge first, it shouldn't be too tight. I'd recommend that before using anything metal. Once the badge has been removed you'll access to tne steering column nut
Andy
andyelan
PostPost by: RichardHawkins » Wed Dec 11, 2024 7:41 pm
Phil,
Thank you, I am most impressed. My phone is an antique. I am so frightened of door trim I would only remove and refit if the work was essential.
Richard Hawkins
RichardHawkins
PostPost by: trw99 » Wed Dec 11, 2024 9:53 pm
You can buy plastic trim removal tools, which are far kinder to plastics, vinyl etc. It is also very useful for our modern cars, where so many bits of plastic need to be removed for all sorts of access to fuses, light bulbs and so on.
I keep a set in my tool kit and it is amazing how often I use them, even on the Elan.
PostPost by: prezoom » Thu Dec 12, 2024 5:20 am
All,
Managed to get a fingernail to catch the edge, and pop it off. Thanks to everyone.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
prezoom
