steering column bushes
Is it possible to replace the rubber bushes without removing the inner column. Does the outer column come off and leave the inner in place? 1969 S4.
- stephenvincent
I did the job on my S4, it was a long time ago, but I am sure you can't replace the bushes with the inner column in place. The inner column is in two parts, there is a clamp joint down by the base of the outer column, in the foot well. If you undo this joint the upper part of the inner and outer column can be removed together. I don't think it's possible to remove the outer and leave the inner in place - unless someone on this site has managed it and can tell us how!
Ray.
Ray.
- Ray419G
In case it helps, I replaced mine ('67 S3) recently using the uprated bushes https://rimmerbros.com/Item--i-209423UR from Rimmer Bros
I followed the advice from the forum and silicone greased the new bushes, constrained them inside a jubilee/hose clip and pushed them into place with a suitably sized socket on an extension bar. They went in with no trouble at all. Together with a new UJ to the rack, they made my steering so much more direct.
Damian
67 French-Blue Elan S3 DHC 45/7001
- DamianB
Just wondering...At what sort of age/mlieage would you expect to benefit from new bushes ?
- lotusposition
Lotus position,
When I bought my S4 Elan, it was 11years old with 55000 miles on the clock. The bushes were completely shot, as was most of the car. Replacement bushes did not produce a decent result. I had the shaft hard chrome plated and ground to fit the bushes.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
Guys, thank you for all of your responses. I might investigate alternative bushes for the steering column.
- stephenvincent
