Steering rack pinion bearing dowel
I’ve managed to lose the dowel that stops the upper pinion bearing from rotating which is frustrating.
Is anyone able to measure one up for length and diameter please so I can try my local bearing shop.
Or if anyone has a spare one I’d be pleased to purchase it.
While I’m at it any guidance on grade for pinion end of rack?
I’m using lithium grease for the bush end.
Vaughan
Vaughan
- vstibbard
Diameter 3.12mm
Length 5.56mm
For some reason I can't get the image the right way up but it will be if you click on it to open it. ???
Length 5.56mm
S4 DHC
S4 DHC
- oldelanman
Sounds like you need to use the shank of an old 1/8" dia twist drill to me. Also your grindstone, don't burn your fingers.
- alan.barker
