Inner tie rods question.
I had my steering rack rebuilt by Kiley Clinton, but it is much too long (wide). I'm guessing the inner tie rods are too long.
They were carried over from the rack I sent them (I thought it was from a Sprint, but evidently it wasn't!) and I guess not checked. It may have Herald or other rods.
So question!
Are +2 tie rods the same as a Sprint if you remove the extension?
Are tie rods for a sprint available?
I see TT have some but they don't say what they are for and are very expensive, about half the price of a new rack from SC parts.
Any other solutions would be appreciated!
So question!
- Bitsilly
The Lotus track rods are approx 1" shorter than the Triumph ones 6" Vs 7" ) .... Brian Buckland's book has the exact dimensions .... so a Herald rack assembly would be around 2" too long overall to fit the Elan. Don't forget also that the Elan rack should have lock limiting spacers and these will not be present if your rack is from a Triumph Herald. Again the dimensions of the spacers can be found in B.B's book.
S4 DHC
S4 DHC
- oldelanman
Hi Bitsilly
The +2 extensions are longer than Sprint. extensions
See attached
Good luck in resolving your problem
See attached
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Users browsing this forum: No registered users and 45 guests
