Steering Bracket Stand-off
Quick question.
Does anyone know why the bracket which attaches the steering wheel clamp to the dashboard has a small stand-off at the top mounting point?
The two lower screws hold the bracket tight to the dash whereas the top one has a 2mm gap. Over-tightening the top screw could potentially crack the dashboard. Is there a reason for this gap? Should it be packed out with washers?
71 Elan Sprint FHC Pistachio
36/0262E
36/0262E
- Bodmin
I just went out to have a look at mine and it has the same 2mm gap. The dash seems straight so I think I'll add a washer or 2. Speculating but maybe the bracket was sourced from another vehicle that has a 2mm difference?
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
Bodmin,
I don’t remember what I did, I forget so much these days, so had to have a look, not difficult as the dash is still not ready to install. To my surprise I find a 2mm thick spacer that I have filed to the profile of the bracket!
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
I’ve just assembled it on my ‘trial fit’ dash with two washers to fill the gap.
I have a new dash in order so don’t want to crack the veneer as soon as it’s delivered.
Can’t believe this issue hasn’t been raised before.
36/0262E
36/0262E
- Bodmin
This issue has cropped up several times in the past. There is an explanation for the stepped bracket in this previous thread...
viewtopic.php?f=42&t=24230
It seems on early cars a fibreglass lug on the scuttle was sandwiched between the dashboard and the bracket, not so on later cars.
S4 DHC
S4 DHC
- oldelanman
Users browsing this forum: No registered users and 45 guests
