Plus 2 Rack Query
PostPost by: 111Robin » Tue Mar 22, 2022 5:11 pm
My rack has a free floating sleeve on the right end (RHD), presumably this is the full lock stop ?. It isn't shown in the factory manual assembly drawing hence the question. It looks like it may be shown in the dimensioned cross sectional view but it's not too clear.
imgonline-com-ua-CompressToSize-gutK74308njeJvs.jpg and
imgonline-com-ua-CompressToSize-Sgg38DTFdHP.jpg and
111Robin
PostPost by: jono » Tue Mar 22, 2022 6:59 pm
Yeah, that's the lock limiter/stop
PostPost by: 512BB » Tue Mar 22, 2022 7:02 pm
Your rack is all correct Robin.
Leslie
PostPost by: 111Robin » Tue Mar 22, 2022 7:46 pm
Thanks Leslie.
I've decided to just fit new cups and reshim the tie rods as there doesn't appear to be much else wrong with it. Time will tell.
111Robin
PostPost by: tonyabacus » Wed Mar 23, 2022 12:15 am
Robin
Whilst its apart just check the main rack for trueness, when the rack is a little worn this does not always show, but when overhauled and re-shimmed, it can be then when any distortion becomes apparent, so worth a quick check now.
tonyabacus
PostPost by: 111Robin » Wed Mar 23, 2022 7:41 am
Thanks Tony, I'll check this also.
111Robin
PostPost by: Hawksfield » Wed Mar 23, 2022 11:08 am
Robin
Also check non pinion end bush as this is the source of MOT failures and there should be a nylon plug in the hole near the non pinion clamping point. all available from Rimmer bros.
goodluck
+2s130 1971
PostPost by: 111Robin » Thu Mar 24, 2022 8:36 am
Are the rack and pinion straight out of a Spitfire rack ?. Just for reference when I'm looking at Rimmers for parts.
111Robin
PostPost by: Hawksfield » Thu Mar 24, 2022 1:37 pm
Yes for the bush and nylon plug
I think SJS sell the bush for the nylon plug, I have the dimensions to make.
+2s130 1971
PostPost by: tonyabacus » Sat Mar 26, 2022 8:56 am
Robin
Somewhere on the forum there is a posting about overhauling the rack, with comments about which parts need checking, but more important it explained the couple of parts that were modified by Lotus when they decided to use the Spitfire rack. These parts will already be fitted to your rack, so the parts you will need to purchase will mainly be the gaiters and fluid.
It may be worth you looking for the posting I mention because I seem to recall there were a couple of pictures. But if not then YouTube has a run through to help, the parts you will need can come from any of the usual Lotus people or for that matter any of the Triumph parts suppliers.
Good luck
Tony
tonyabacus
PostPost by: 111Robin » Sat Mar 26, 2022 9:09 am
Thanks Tony, much appreciated.
111Robin
PostPost by: Roland » Wed Mar 30, 2022 7:38 am
Get Kiley Clinton in Birmingham to refurbish it if in the UK. They are not that expensive and you will know it's correct once done
Roland
PostPost by: 111Robin » Wed Mar 30, 2022 7:51 am
Roland wrote:Get Kiley Clinton in Birmingham to refurbish it if in the UK. They are not that expensive and you will know it's correct once done
Yes thanks, I have contacted them previously however my rack doesn't need a full overhaul at the moment. If/when it does I will be using them.
111Robin
PostPost by: 111Robin » Wed Mar 30, 2022 8:01 am
On another point, when I tighten the clamps they are tending to be pulled off the rubbers as the U bolt is offset to one side of the rubber, as you would expect. I have found a photo of another clamp that has additional supports presumably to prevent this from happening. Was this a later modification or are my clamps just missing these parts ?. My clamp is the second photo.
Screenshot 2022-03-30 085311.jpg (90.22 KiB) Viewed 391 times
Screenshot 2022-03-30 085441.jpg and
111Robin
Users browsing this forum: No registered users and 44 guests
