STEERING LOCK SPRINT,
PostPost by: geni » Wed Oct 28, 2020 2:10 pm
who can confirm or say the origin of the steering column blockage for Sprint?
Triumph Spitfire gt6? or other model?
geni
PostPost by: pharriso » Wed Oct 28, 2020 4:03 pm
I believe it's the Spitfire, GT6 & TR6. See the parts digrams listed under https://rimmerbros.com/Item--i-158459
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Esprit2 » Wed Oct 28, 2020 6:00 pm
Geni,
I'm not certain I know what you're asking for. Phil posted a source for the switch. If that's not what you're after, then can you expand upon the description.
"Blockage". ?? If you're looking for the steering lock spacers that limit how far the wheels turn in either diredtion, that was in the rack itself, not the column, and it was Lotus-specific. The rack was an Alford & Alder part similar to the one used in the Triump Spitfire for the Elan & Europa, and in the GT6 for Elan +2, but built with some Lotus-only parts... including the spacers that determine the steering limiters (blockage ?). If that's what you want, there is no "Triumph" specialist who will have them... try Sue Miller at Mick Miller Classic Lotus, http://www.mickmillerlotus.com/
... or any of the more Elan centric Lotus specialists.
Or, given the dimensions, they're simple sleeve spacers any local machine shop could make for you. If that's what you're looking for, I'll see what I have in the way of dimensions.
If you're looking for something else, could you please describe it more.
Tim Engel
Esprit2
PostPost by: pharriso » Wed Oct 28, 2020 6:39 pm
Esprit2 wrote:Geni,
I'm not certain I know what you're asking for. Phil posted a source for the switch. If that's not what you're after, then can you expand upon the description.......
Tim Engel
Tim, if you follow the link it goes to the switch, but below it are the parts diagrams for the TR6, GT6 etc showing the column housing etc...
Phil Harrison
PostPost by: geni » Thu Oct 29, 2020 7:48 am
Pour mieux comprendre,
il s'agit d'un ensemble sécurisé fixé à la colonne de direction montante, comprenant l'interrupteur à clé et l'ensemble du système de verrouillage bloquant la rotation de la colonne sur la direction.
Cela ne se trouve que sur le Sprint!
geni
PostPost by: pharriso » Thu Oct 29, 2020 10:07 am
geni wrote:Pour mieux comprendre,
Google translated to:
To better understand,
it is a secure assembly attached to the rising steering column, comprising the key switch and the entire locking system blocking the rotation of the column on the steering.
This is only found on the Sprint!
Mais Oui!
This assembly that RDent sells:
p.s. The same assembly is used on later Plus2s & Europas.
Phil Harrison
Users browsing this forum: No registered users and 44 guests
