Rack mounts and UJ advice please
To go along with the rack thread I started earlier, I am thinking of refitting with a solid UJ and solid rack mounts rather than the original OEM rubber items. That was how our Caterham, that the Sprint has replaced, was set up and worked well.
Is this a good idea with an a Elan please or will it loose its classic character.
Harry
Harry
- HJF
Hi Harry,
personally I don't like the solid rack mounts having tried them on my Sprint, and have reverted to a set of new standard mounts with standard rubber inserts (SJ Sportscars supplied). I also like the standard UJ coupling.
I've had two Sprints and if the rack and all the steering joints are in good condition the standard setup is perfectly geared and excellent for feel and feedback. The solid mounts I felt just made the car feel a little nervous and did not improve the experience, it felt a little like fitting a smaller steering wheel - definitely not needed!
Iain
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
There is also a middle ground of poly mounting bushes. I have these on mine and happy enough with them, good steering with out the downsides of solid mounts.
Which is right answer is likely very personal and effected by the rest of the steering setup/condition.
- mbell
Now I have successfully freed the stuck UJ, see my other thread, I am about to order a new UJ. So, minded now to fit a standard rubberised UJ in view of the comments above. How long do the standard UJs last and are they decent quality? Am aware a lot of car parts are cheaply made in the third world and that rubber components don’t seem to last as long as they did.
- HJF
I've had standard, poly, and solid rack mounts. All 3 at different times in my S1. Personally I prefer the feel of the solid mounts, especially when driving "spring finger" style. Certainly no downsides to them from my perspective, but preferences will vary.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Hi I have solid mounts and the feel is very good. The reason I went for solid mounts was that when shimming the mounts to correct the bump steer I actually needed to take one side down a little and you can't do thus with the original type.
- Concrete-crusher
HJF wrote:Now I have successfully freed the stuck UJ, see my other thread, I am about to order a new UJ. So, minded now to fit a standard rubberised UJ in view of the comments above. How long do the standard UJs last and are they decent quality? Am aware a lot of car parts are cheaply made in the third world and that rubber components don’t seem to last as long as they did.
I wonder if anyone has started making the rubber cone inserts in Poly ??
Hi John,
Have had poly cones fitted in the steering universal for years.
https://superpro.com.au/find/superpro-s ... -999500028
I have polyurethane bushing throughout my Elan. If you trawl through the Superpro site, looking under Lotus and Triumph, you can find all you need.
Colin.
te="john.p.clegg"]
John [/quote]
Colin.
te="john.p.clegg"]
John [/quote]
'68 S4 DHC
- fatboyoz
fatboyoz wrote:Hi John,
Colin.
Thanks for the reminder Colin. I have had Superpro bushings in my Elan for 30 years as Historic racing regs in Group Sb dont allow rose joints in the suspension and I noticed the D shape roll bar bushings I used for the bigger roll bar were looking the worse for wear when I pulled the engine recently. Time for a refresh, cant complain on their life. The bushings in the rest of the suspension are still perfect !
HJF wrote:To go along with the rack thread I started earlier, I am thinking of refitting with a solid UJ and solid rack mounts rather than the original OEM rubber items. That was how our Caterham, that the Sprint has replaced, was set up and worked well.
Harry
I fitted solid rack mounts and solid UJ to my Plus 2 many years ago. The steering is much sharper and I haven't notice any unpleasant side effects.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Would you think, a combination. Of thicker, more rigid steel, and thinner rubber? Or poly
Love your Mother
Earth
Love your Mother
Earth
Users browsing this forum: No registered users and 46 guests
