S2 26R rack stop tube spacer
PostPost by: jabingb » Thu Jun 04, 2020 3:14 am
I have a 1.75" long spacer on the left side (non pinion) and nothing of the right side, am I missing something, believe that's the standard Elan setup? I also thought I read somewhere the 26R spacers were of a different length (because of the bigger tires and/or larger diameter anti-roll bar)?
Jerry:
'61 S2 Elite | '69 S4 Elan FHC | '00 S1 Elise Sport 190
jabingb
PostPost by: oldelanman » Thu Jun 04, 2020 10:04 am
I don't know about the 26R but a 1.75" spacer on the free end and 0.28" on the pinion end of the rack is correct for standard S1-S3 road cars. The short pinion end spacer is tack welded to the lock nut so may not be obvious at first glance. On S4 cars the spacers were increased in length to 2.0" and 0.53" to accommodate the change from 145 to 155 tyres.
Edit: There's discussion about additional spacers in this thread from a couple of years ago ... could that be where you saw it perhaps ?
viewtopic.php?f=31&t=37259&start=60
S4 DHC
PostPost by: 1owner69Elan » Thu Jun 04, 2020 6:29 pm
oldelanman wrote:I don't know about the 26R but a 1.75" spacer on the free end and 0.28" on the pinion end of the rack is correct for standard S1-S3 road cars. The short pinion end spacer is tack welded to the lock nut so may not be obvious at first glance. On S4 cars the spacers were increased in length to 2.0" and 0.53" to accommodate the change from 145 to 155 tyres.
Just to reiterate in reference to the previous thread, you can effect the spacers needed for a 26R, or in my case an S4, to accommodate wider tires and consequent fouling of the ARB via use of clip-on spacers. Can be installed in situ as well as dialed in to the precise size needed.
IMG_7556.jpeg and
IMG_7553.jpeg and
Clip-ons from Mustang shown in the middle. (Outer ones are for a Mini and are not clip on).
'69 Elan S4 SE
Street 181 BHP
Original owner
Users browsing this forum: No registered users and 44 guests
