steering coupling rubbers
PostPost by: Sandals man » Wed Oct 17, 2018 9:28 am
20181017_105835.jpg and
20181017_105316.jpg and
Hello everybody,for my elan s3 1967 I am searching the rubbers for the steering coupling.see pictures.Can not find on the internet.
Thanks for helping
Willem from Holland
Sandals man
First Gear
First Gear
PostPost by: oldelanman » Wed Oct 17, 2018 10:22 am
Hi Willem,
I have seen a repair kit for the original style coupling on-line somewhere but can't find it now.
Edit: Found some poly bushes (see also other link in post below........http://www.jamespaddock.co.uk/steering- ... urethane-2
Replacement couplings are widely available in the UK ... try these.....
https://www.sjsportscars.com/parts-and- ... 0H0001.htm
https://kelvedonlotus.co.uk/product/ori ... ing-joint/
https://www.moss-europe.co.uk/coupling- ... soc=151976
https://www.sportscarsupplies.com/lower ... -989-p.asp
S4 DHC
PostPost by: john.p.clegg » Wed Oct 17, 2018 10:24 am
It's about time someone started making these in poly...
John :wink:
PostPost by: oldelanman » Wed Oct 17, 2018 11:13 am
john.p.clegg wrote:It's about time someone started making these in poly...
John :wink:
https://www.ebay.co.uk/p/Triumph-Spitfi ... 477&chn=ps
:wink: :wink:
S4 DHC
PostPost by: john.p.clegg » Wed Oct 17, 2018 1:19 pm
:oops:
John :wink:
PostPost by: RichardHawkins » Thu Oct 18, 2018 7:54 pm
Willem,
I can't comment on the other suppliers, but I bought from Moss, and the quality is appalling, borderline dangerous.
Richard Hawkins
RichardHawkins
PostPost by: john.p.clegg » Thu Oct 18, 2018 9:14 pm
Last time I needed some i made some out of PTFE rod in the lathe...
John :wink:
PostPost by: Chrispy » Fri Oct 19, 2018 7:00 am
I used a poly kit from Lotus Marques here in Australia. Kit quality was fine, but it's just a poor original design. Mine has slop in it already. Will be putting a proper uni joint in when I get the chance.
Elan +2 #0245
Exige S2 Supercharged
Chrispy
PostPost by: mikealdren » Fri Oct 19, 2018 8:09 am
I've bought a UJ for the job, no play in it at all but of course, it isn't a CV joint. Will this be an issue, anyone tried one?
mikealdren
PostPost by: john.p.clegg » Fri Oct 19, 2018 8:29 am
I had one for years , great mod , but had to grind it down a bit on the outsides before fitting as it was very close to the bottom hose.....adding lightness..
John :wink:
PostPost by: 69S4 » Fri Oct 19, 2018 9:53 am
I've bought a number of those couplings over the years and always found the rubber didn't last long. About six or seven years ago I rebuilt one using 'washers' of rubber cut from fuel injection hose. That's on my car at the moment and working well. I tried taking another one apart to do the same but the bolts proved very difficult to undo and two of them sheared off. When the current one gives up I'll probably change it for a UJ type.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
