Changing Top Steering Joint
I will need to change at least one of these joints on my +2 over the winter. It's the one that connects the top wishbone to the upright.
Looking at the suspension, it seems that with the car jacked up and the suspension drooping, there is no force from the front springs on this joint, so I do not have to compress the front springs. I just have to catch the hub as the joint is removed as it rotates outwards.
Is that right?
Dave Chapman.
Is that right?
Dave Chapman.
- david.g.chapman
Thanks Rohan and Jim.
I discovered one of my joints had a split gaiter but was otherwise OK. I sewed up the split and sealed with RTV, but the gaiter is perishing so the joint will have to be replaced before too long.
Dave.
Dave.
- david.g.chapman
2 new ball joints ordered from SJ Sportscars. ?31 inc VAT and postage - not bad.
Dave.
Dave.
- david.g.chapman
The first type is guaranteed to split the gaiter, I still have mine and its the best for getting joints apart if you are going to replace the joint or have a spare gaiter, on the old Minis it was good for the top and bottom swivel joints because the gaiter was just a cap and would slide out of the way.
Some impressive rust on the one in the photo, mine has always been covered in grease and grime and the plating is still like new.
- Chancer
Chancer wrote:The first type is guaranteed to split the gaiter, I still have mine and its the best for getting joints apart if you are going to replace the joint or have a spare gaiter, on the old Minis it was good for the top and bottom swivel joints because the gaiter was just a cap and would slide out of the way.
Yes, clearly I haven't used it for 30 odd years and it was hidden away in an old tool box. Back then I use to do all my own suspension work. The swivel joints in those days had a transparent gaiter and were beefier and probably longer lasting than the ones today. Jim
- JimE
The problem is for that to work it needs metal to metal contact, one side of the wedge against the steering arm the other against the outside of the joint but it has to cut through the gaiter to do that and one whack of the hammer will slice straight through it.
I rarely have to resort to using either of my types of seperator, some things you dont lose even after 20+ years and how to hammer a ball joint apart is one of them for me, where to hit it, how to hit it, what direction (that with most resistance) and whether a 2nd hammer as a reaction mass is needed, I am dissapointed if I need more than one hit, inconsolable if my aim is off and I damage the gaiter.
- Chancer
+1 for two hammers but mind the wing when you swing
Boots can be bought from sjsportscars
- alan.barker
I never managed to get the "belt it each side with 2 hammers" system to work.
Figuring as the joint was going to be discarded anyway, I took a hacksaw to it, and chopped the top off leaving the taper in the upright.
Then got a big "G" clamp, and a socket, and pressed the taper out.
Ralph.
Ralph.
- reb53
The problem with the two hammer approach is that you have to do it from the side of the joint and the wheelarch severely limits the swing and hence momentum, its fine on a rolling chassis.
That is why I use one hammer at 90? to the axis of the inner wishbone pivot, you have the maximum distance from the bodywork and the suspension is at its stiffest in that direction compared to fore and aft.
The 2 hammer method definitely works but to be really effective the stationary one needs to be a much larger mass, there usually just isn't room and access on a vehicle suspension.
Like most things its something I intuitively learned and later on saw Professional mechanics doing it the same way, I've never seen one use 2 hammers to release a mounted suspension ball joint, when you do something day in day out, and when I was Young I was working on cars full time, you adopt the simplest most effective methods and adapt for situations where they dont work.
If I had an upright complete with upper and lower wishbones removed from a vehicle by a breakers yard for instance I would use 2 hammers or one hammer and just a sledgehammer head or another suitable mass.
- Chancer
