In and out play in steering wheel
Check the universal joint at the bottom of the steering column, there is about 1/4" of movement on that. Then check the collapsible joint part way up the column. Torque setting for this should be in the manual.
Last but least likely, the nut in the steering wheel.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
If you have a solid early steering column, there will be no sliding joint to check - I would have a look there anyway.
It could also be a loose pinch bolt at the bottom of the steering column where it connects to the rack. It is possible to pull the steering column right out if this bolt falls away, leaving you without steering!
I would check this urgently if the car is on the road.
Dave Chapman.
Dave Chapman.
- david.g.chapman
Just a few thoughts on this matter.
Looking at the diagram of the steering column, item 1, you can see that at the lower end where it fits into the flexible joint, the 'flat' on the shaft is about 1/4 to 1/2" long, so if the pinch bolt of the universal joint is not done up tight the shaft can move up & down a little.
At the top end of the shaft you see a long flat which is the column collapse area. The pinch clamp (3,4,5) should be highish on this area but should slide to the bottom of the flat if your body impacts on the steering wheel. If the pinch bolt is not pressing on the shaft properly it may slide UP & Down a little and worst of all might gouge a quarter inch groove in the shaft
Furthermore I recall that early flexible joints were not bearings, but merely a flat disk of rubber (a sort of miniature doughnut See 9 below)).
This had a small amount of up & down flexibility but is not a problem.
davie489 wrote:Finally come to the conclusion the car is trying to kill me!
Wheel coming loose in fast lane of motorway last month and today the wheel and shaft came completely off the steering rack!
It would be more accurate to say that you are trying to kill yourself!
One of the first replies to your original question advised urgent attention......
As it happens tonight I intended to ask how the matter had been resolved, your post above explains it quite well.
Seriously I suggest that if this car is new to you, that you get it checked out generally.
Please take care.
Ian
Elanman99 - Third Gear
Losing the steering connection is the worst possible thing to happen, I am glad your Ok.
The rack pinion shaft and steering shaft both have grooves in them that the pinch bolts for the couplings fit in so it is impossible for the shafts to come off if the bolts are present. ??
Rohan, unless undersize bolts are fitted. Either way, something is wrong and it's no the car's fault if it's incorrectly assembled.
Some columns have a flat rather than a circumferential groove, and only the tightness of the pinch bolt can prevent a half-inch or so of play. A little loctite can help, the kind for splines.
RogerFrench - Fourth Gear
