Steering rack grease access
PostPost by: Concrete-crusher » Fri Nov 18, 2016 6:11 pm
Hi , looking at my steering rack I can't see there's enough room to fit a grease nipple as the body looks quite close at that point. Do you need to cut away the body to gain access , or should the rack be removed to inject the 5 pumps of greaes refered to in section O of the manual.
Thanks in advance for any advice.
Concrete-crusher
PostPost by: Bill » Fri Nov 18, 2016 7:14 pm
There was no grease fitting on mine. Way back when I solved it this way. Cut an access hole (about 2" dia) thru the front pan directly above the steering box, remove the plug in the cap and replace with a grease fitting, mine has a ground wire connection there - keep it.
I did that 50 years ago - good memory huh!!
Bill
Bill Rathlef
Vancouver Island, Canada
Bill
