Wobbly wheel
PostPost by: LaikaTheDog » Sun Oct 23, 2016 6:08 pm
I have squirrelly steering.
I have found that my offside front wheel has play in it. On the horizontal. None perceptible vertical.
At first I thought it was the torque of the stubb. So I checked it at 68lbft as per manual.
But I still have play. The disk and wheel, in fact the whole hub seems to have play.
Could it be a knackered bearing ?
Other side is fine !!
LaikaTheDog
PostPost by: englishmaninwales » Sun Oct 23, 2016 6:17 pm
Check for wear in the track rod end or steering rack. Could also be the wheel bearing, but I find that is best felt in the vertical plane.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
PostPost by: denicholls2 » Tue Oct 25, 2016 2:32 pm
Hope it is in the tie rod end (called track rod above). It can also be in the rack. And if so, much more difficult to cope with. You can replace rod ends quickly and inexpensively, if in North America I recommend British Parts Northwest (early Spitfire).
denicholls2
PostPost by: billwill » Tue Oct 25, 2016 4:54 pm
The problem might be the ball joint at top of the upright.
