Spyder Power Steering
PostPost by: Robzildjian » Fri Apr 29, 2016 1:01 pm
Hi all,
Has anyone tried the power steering option for the plus 2 Zetec from Spydercars? Opinions appreciated.
Rob
image.jpeg and
Robzildjian
PostPost by: Sea Ranch » Fri Apr 29, 2016 2:23 pm
Is that a delayed April Fools' joke?
Sea Ranch
PostPost by: msd1107 » Fri Apr 29, 2016 3:38 pm
Why would a person need power steering in a Lotus????
msd1107
PostPost by: Spyder fan » Fri Apr 29, 2016 6:11 pm
Rob,
I hope to have a go next week and will report back. The system utilises an electric power steering unit from a Vauxhall Corsa or similar. It fits under the dashboard inside the car.
Steering effort at parking speeds is quite heavy on a Spyder +2 Zetec conversion, wider stickier tyres don't help matters. Its not an upgrade I'm planning myself, but it doesn't hurt to try it out.
I would rather spend the money on the new Air Con upgrade
Kindest regards
Alan Thomas
Spyder fan
PostPost by: holywood3645 » Fri Apr 29, 2016 8:13 pm
I think these are the same items that are sold for the MK1 and Mk2 ford escort. May be worthwhile to check those sites out.
James
PostPost by: Sea Ranch » Fri Apr 29, 2016 8:41 pm
Ah . . . "new air con upgrade" . . . now you've got my attention :mrgreen: :mrgreen:
Sea Ranch
PostPost by: gus » Sat Apr 30, 2016 1:12 am
I'm a fan of Spyder, but if they need power steering in a plus two, there is something wrong. I've run 205's for 25 years and never wanted it. Shimmed in a degree of castor and it made it just a touch heavier at a standstill, but to the extent that my finger gets dented spinning with the wheel spoke
gus
PostPost by: SimonH » Sat Apr 30, 2016 8:27 am
I expect it's more a case of what customers have asked for than needs it.
Just because an enthusiast doesn't want it doesn't mean it shouldn't be offered.
SimonH
PostPost by: Robzildjian » Sat Apr 30, 2016 8:32 am
Thanks Alan and James - very helpful.
Rob
Robzildjian
PostPost by: Robzildjian » Sat Apr 30, 2016 10:41 am
Incidentally, I don't think I want it either but I was just interested from a technical perspective in how good it is.
Robzildjian
PostPost by: elan66 » Sat Apr 30, 2016 5:29 pm
man up :roll: :lol:
elan66
PostPost by: gus » Sat Apr 30, 2016 9:26 pm
I have driven small cars[an 85 CRX comes to mind], that needed power steering. Many modern cars though small, weigh quite a bit, and with front wheel drive putting all that weight up front, and torque steer etc, power steering is a welcome addition in many cars. My former M100 had power steering and I was not offended, but people have asked my if the Plus Two had power steering when watching me park, so it is bewilderment at the need or desire more than dogmatic fist shaking that makes me comment.
I have quite literally driven my Plus Two with two fractured elbows with no ill effect, so that is my perspective...........
gus
PostPost by: Spyder fan » Sun May 01, 2016 4:28 pm
The steering geometry is different on a Spyder Zetec, it doesn't use the Triumph steering rack and the hubs and uprights are from a Ford Sierra, steering effort is increased over a standard +2. I don't have a problem with it, but those used to moderns or those encouraging partners to drive may have.
Kindest regards
Alan Thomas
Spyder fan
PostPost by: gus » Mon May 02, 2016 12:14 pm
Wonder if they have reduced the turns lock to lock, lots of castor, or some other thing that increases effort
gus
PostPost by: Foxie » Thu May 19, 2016 12:35 am
Spyder fan wrote:The steering geometry is different on a Spyder Zetec, it doesn't use the Triumph steering rack and the hubs and uprights are from a Ford Sierra, steering effort is increased over a standard +2. I don't have a problem with it, but those used to moderns or those encouraging partners to drive may have.
I have converted my Plus 2 to the Sierra hubs and vented discs. The wishbone are identical geometry to the originals. The hubs are Sierra, but the uprights themselves are exactly similar to original Lotus, except for the bottom ball joints. So it would seem the steering geometry is unchanged. I don't know the gearing of the Zetec rack, so steering effort might be different. :D
68 Elan +2, 70 Elan +2s
Next
