1970 Elan flexible steering coupling
Hello
How the heck does anyone manage to remove this U/J from the steering column ??
Mine is locked bl~~dy solid !
- lotusposition
You have to get the clamp bolts completely out, since, they intrude into the circumference of the steering shafts, to prevent them sliding off (if they loosen only a little amount).
I found that with the bolts out, I still needed to tap a wedge (Old screwdriver blade ? ) into the slot to try widen the clamp.
Lots of a good release agent too, Plus Gas rather than WD40.
Thanks, Bill.
Have done all the above and still stuck fast to the column.
Will keep at it !
Will keep at it !
- lotusposition
