steering wheel compatability
Hi, I've just ordered a Momo steering wheel from Demon Tweeks without getting an adaptor "boss".
When I ask for the appropriate boss I'm advised by them that the Momo don't make one for the Elan.
This has to be wrong.
Can anyone tell me the vehicle that the steering column is compatible or common with so I can give them an alternative make?
thanks in anticipaation,
David Tye
David Tye
- David tye
David tye wrote:Hi, I've just ordered a Momo steering wheel from Demon Tweeks without getting an adaptor "boss".
David Tye
Hello David,
It would be the same for a Triumph Spitfire.
Hi David
Momo used to make a boss for the Triumph Spitfire steering column but it was discontinued many years ago. The part number was 211511.7800.
More recently (although I'm talking 8 years ago) I was able to obtain a Mountney boss which was compatable with the Triumph column and Momo steering wheel. The number for that was MTNKK1029X 241006.
If this doesn't help, you might want to try one of the race guys such as Pat Thomas or Tony Thompson
Andy
Andy
- andyelan
My S1 Elan has a 5/8" diameter 36 spline shaft. As others mention, a Spitfire boss works. Pegasus racing sells 3 bolt to 6 bolt adaptors, which may give you additional options.
For my car, I purchased a quick release adaptor from Schroeder Racing (in the U.S.) with 6 bolt mounting. With minor modifications, it works well.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
David,
If you are anywhere near Cambridge (the UK one), I have a Mountney one you can try? I used it on my Sprint when the original wheel was off being recovered. It's a Triumph Spitfire one
Carl
Carl
pereirac - Fourth Gear
and if you're anywhere near Manchester you can try my spare....
P.S. Location helps.
i thought the early shaft dia was Ford and the later shaft was Triumph
- alan.barker
