Steering Column Question
I have just removed the steering column from my Elan and noticed that the metal channel clamped to the outer column is missing (the wiring to the indicator/headlamp stalk switches runs in it). As I have a column modified to take a steering lock, would this channel piece have been fitted when it left the factory as it looks as if it would be in the way of the lock? The lock itself is not fitted nor are there any witness marks on the column to suggest that one ever has been.
As the ignition switch is dash mounted, I assume that the steering lock, when fitted, did that roll only ie locked the steering. It is the Sprint that has the ignition switch/steering lock combined.
It would be good to see a photo of an S4 fitted with the lock to clarify the installation details.
Karl
1970 S4 FHC SE
1970 S4 FHC SE
fasterbyelan - Second Gear
Do a search & there is a post where I show all the components.
Don't think any S4s cam with steering column mounted ignition switches, early sprints had dash mounted ignition switches.
Even with a column mounted switch, that shroud should be there as it stops the colum outer from rotating.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Not necessarily! On my Sprint with column lock and integral ignition switch, there is a special bracket that clamps round the lock and is bolted to the column support casting - you can see it in my photo. This is very effective at preventing column rotation and I have no channel under the column for the wiring.that shroud should be there as it stops the colum outer from rotating.
As I needed a new electrical ignition key switch, I bought a new column lock from a well known supplier, but it had a square barrel, which made it impossible to fit this bracket. So I removed the new switch from the new lock and grafted it onto the old barrel. All fine now.
TroonSprint - Fourth Gear
pharriso wrote:Do a search & there is a post where I show all the components.
Thanks, I'm now looking for a cable shroud! And......................the outer column lower mounting clamp is missing (and packing felt). The bracket is however there.
The wanted list gets longer every day.........................
Karl
1970 S4 FHC SE
1970 S4 FHC SE
fasterbyelan wrote:Thanks, I'm now looking for a cable shroud! And......................the outer column lower mounting clamp is missing (and packing felt). The bracket is however there.
Cable shroud is readily available, it's available in the UK from Rimmer Brothers http://www.rimmerbros.co.uk/Item--i-GRID005792- Part # 611369 it's a Triumph Spitfire part
Phil Harrison
pharriso wrote:fasterbyelan wrote:Thanks, I'm now looking for a cable shroud! And......................the outer column lower mounting clamp is missing (and packing felt). The bracket is however there.
Thanks for the info, I can also get the felt packing strips for the lower clamp from the same place. I just need to find a lower clamp now...................
Karl
1970 S4 FHC SE
1970 S4 FHC SE
pharriso wrote:Which bit are you calling the lower clamp?
Is it shown in this parts diagram?
Item 22, the lower parts.
I have managed to source one from Rimmer's so will be picking up all the parts I need from them at the NEC Classic Car Show on Friday,
Thanks again.
Karl
1970 S4 FHC SE
1970 S4 FHC SE
