Steering universal joint
For some reason the rubber washers have failed very quickly in my rebuilt UJ, not lasting for years like they did last time.
Does anyone know what car has a suitable needle bearing type?
I started on the archives but when I got to the suggestion that lots of Jap cars have 13mm ones, which are near enough to 1/2, and even though they have a different numbers of splines all you have to do is tighten them up really tight......
Apart from buggering the splines on both the column and the rack I knew I'd never trust it.
Anyone got any actual brand/model/year info on this ?
Otherwise I'll be back to grinding some new washers.
Thanks.
Ralph.
Thanks.
Ralph.
- reb53
http://www.ebay.com/itm/TRIUMPH-Spitfire-Herald-GT6-Vitese-Lotus-Elan-LOWER-STEERING-U-JOINT-Upgrade-/141403101735?pt=Motors_Car_Truck_Parts_Accessories&hash=item20ec481a27&vxp=mtr
I have had one of these for more than 20 years. Works perfectly.
Dan
Dan
Ralph,
I use these in the original U/J.
http://www.ebay.com.au/sch/i.html?_from ... k&_sacat=0
Colin.
Colin.
reb53 wrote:For some reason the rubber washers have failed very quickly in my rebuilt UJ, not lasting for years like they did last time.
Thanks.
Ralph.
'68 S4 DHC
- fatboyoz
I bought a "proper" UJ from Kelvedon - ?38.60 including VAT.
TroonSprint - Fourth Gear
Ralph
There's not a lot of room down there next to the bottom radiator hose and some u/js are larger than others,can't remember which u/j I used but do remember grinding off the radius surplus metal to clear the hose...
I recently bought one from British Victoria in the US for ~$50 its standard Triumph part. Was quite bulky more than expected, fitted fine on my +2 with it's radiator a more forward than standard. Not sure it would fit an Elan thou.
- mbell
Thanks for all the replies.
I wasn't aware that there was a readily available one ex Herald/GT6/Vitesse etc.
Thought I'd be scratching around wreckers yards as usual....
Place in NZ had one. Ordered yesterday, arrived, and fitted, this morning, and MOT'd this afternoon.
Summer is under way !
Was expecting a huge thing that would be a pain to fit but, as can be seen from a photo I took of old and new types, it was a reasonable size and only about 1 cm longer.
Ralph.
Ralph.
- reb53
If it helps I replaced the rubber washers with a flexane set. and replaced the bonding lead across the joint,.... bingo horn works
Graeme
Graeme
LOTUS Evora 400
Ginetta G27 S2
66 one-off 2.6Ltr v8 Mid-engine Berlinetta Coupe........... in restoration
..................................................Age doesn't matter unless you are a cheese................................................
Ginetta G27 S2
- au-yt
