Springall Steering Wheel
PostPost by: olivier » Wed Apr 17, 2013 11:28 am
Hello,
I have recently bought a Springall steering wheel (not leather but plastic) and I am searching for the horn push. Problem is that I don't know what is the proper horn push that fit my steering wheel.
is someone have a picture or could give me the reference ?
Thank you
olivier
First Gear
First Gear
PostPost by: peterexpart » Wed Apr 17, 2013 5:33 pm
If you are looking for a Springall Horn Push I have one as I also just fitted a brand new springall Wheel but fitted a Lotus Horn Push, with a lot of fiddling and cutting !!!!
PeterExpart
New Forest National Park
Hampshire UK
peterexpart
PostPost by: olivier » Wed Apr 17, 2013 6:13 pm
Here are some pictures I hope that helps
P1060591.jpg and
P1060589.jpg and
P1060584.jpg and
P1060583.jpg and
P1060582.jpg and
P1060580.jpg and
P1060579.jpg and
olivier
First Gear
First Gear
PostPost by: Mazzini » Wed Apr 17, 2013 7:31 pm
That looks remarkably like a S2 Europa wheel, I don't have one to hand to check the measurements, but if it is a Lotus horn push should be a perfect fit.
The wheel was also fitted to S3 S/E's - I can list some period road tests if you're interested?
PostPost by: olivier » Thu Apr 18, 2013 6:45 am
Mazzini wrote:That looks remarkably like a S2 Europa wheel, I don't have one to hand to check the measurements, but if it is a Lotus horn push should be a perfect fit.
Yes it is a Europa steering wheel :D
olivier
First Gear
First Gear
PostPost by: olivier » Thu Apr 18, 2013 6:55 am
peterexpart wrote:If you are looking for a Springall Horn Push I have one as I also just fitted a brand new springall Wheel but fitted a Lotus Horn Push, with a lot of fiddling and cutting !!!!
Hello
That is what I am searching for, could you please post a picture and the measurements ?
olivier
olivier
First Gear
First Gear
PostPost by: Mazzini » Thu Apr 18, 2013 11:01 am
Hello,
I don't know what sort of Springall wheel peterexpart is working on, but Springall made many different wheels for other makes of cars, perhaps his was not meant for a Lotus?
You have a Europa S2 wheel, it should have a thin alloy ring on the inside of the boss where the badge sits. The Europa S2 had exactly the same type of centre badge / horn push as fitted to Elan S1 to 4's and some Sprints as well - the badge should pop right in with minimal fitting.
Under the badge is a three pronged clip that is attached under the steering wheel nut, the badge has cut outs that clip in place. Don't forget the horn push pencil. It's all Standard Truimph stuff and readily available.
Have a look in the Lotus workshop manual or perhaps some of the Triumph sites have exploded diagrams.
Good luck,
PostPost by: nkat » Thu Nov 07, 2013 2:37 pm
Hallo Team.
I am looking for one of these for my 70 Elan S4. Well, mostly a 70 Elan S4. Well, it looks like a 70 Elan S4....
Anybody know where I could get one, please?
Many thanks,
Nigel.
nkat
New-tral
PostPost by: theelanman » Thu Nov 07, 2013 3:00 pm
the std triumph horn push fits.......buy one without a logo
the same lucas item with a lotus 'silver' badge seems to be x10 the price...
or you can buy a copy from S&J sportscars for about ?40...its the wrong period of lotus logo but its still a lotus logo
whilst its not perfect, personally I think its better than nothing
http://www.sjsportscars.co.uk/index.php?mod=10
SJ036H0002
theelanman
PostPost by: theelanman » Thu Nov 07, 2013 3:02 pm
triumph style
http://www.ebay.co.uk/itm/TRIUMPH-TR4-5 ... _162wt_958
I have seen these in just black with no logos
theelanman
