Steering rack: no of teeth on pinion
PostPost by: Higs » Thu Sep 27, 2012 6:51 am
I have stripped my steering rack ('68 Plus 2) and need a new rack bar and pinion. The supplier says that a Plus 2 has a 6 tooth pinion - but of course my Plus 2 has one with 7 teeth. (Note that the rack can accept either a 6 tooth or 7 tooth pinion - so the rack is no help here.)
Searching the archives, there is some discussion about turns lock to lock - and therefore pinion teeth numbers but no definitive answer on whether the Plus 2 was different from the Elan - or if this changed over time or not.
Does anyone have any information that could help?
Higs
PostPost by: seriouslylotus » Thu Sep 27, 2012 7:12 am
Yes 6 and 7 toothed pinion where available fo the Triumoph steering racks The Triumph GT6 had a 6 toothed pinion ad the Herald a 7 toothed pinion.
Have a good search in here
http://www.canleyclassics.com/?xhtml=xh ... d1360.html
Part numbers and models etc etc
seriouslylotus
PostPost by: andyelan » Thu Sep 27, 2012 7:43 am
Hi Everyone
I can say for definite that my '73 Plus 2S130 has a 6 tooth pinion and my '74 Europa Special has a 7 tooth pinion, otherwise the racks are identical. I assume the 2 seat Elan uses the same 7 tooth pinion as the Europa and I have a suspision early Plus 2s did too, however, I have no proof of this.
In my opinion the 6 tooth pinion on the Plus 2 makes the steering far too light and I believe it is this which has given rise to some owners complaining of a rather vague floaty feeling with the car.
It's my intention to try replacing the pinion on my Plus 2 with a 7 tooth when I get time, but the biggest problem doing this at the moment has been finding anyone who actually has one for sale
Andy
andyelan
PostPost by: Higs » Thu Sep 27, 2012 9:09 am
Andy
Thanks for this info.
You can get the bits from Kiley-Clinton in Birmingham:
http://www.steering-racks.co.uk/
Very helpful and they do stuff for Paul Matty (other than they proposed the 6 tooth pinion - but if their was a change later in production then that would explain things).
Higs
PostPost by: ardee_selby » Thu Sep 27, 2012 9:52 am
The +2 parts list (1976 edition) doesn't reflect any change points for the "steering unit assembly". Implies same used up to that date...whatever it was.
Cheers - Richard
ardee_selby
PostPost by: types26/36 » Thu Sep 27, 2012 10:07 am
Here is an interesting article regarding Triumph racks and mentioning no. of teeth.
http://www.tsoaq.org.au/technical-information/22.html
types26/36
PostPost by: Higs » Thu Sep 27, 2012 5:09 pm
To move this forward, I would like to do a poll.
Could anyone who has a Plus 2 and could be bothered please reply with the approximate number of turns from lock to lock?
I am looking for answers to the nearest 1/4 of a turn or so. They should be in the range of 2.5 - 3.5. Telling us the model of Plus 2 would b useful as well.
Thanks.
Higs
