Steering Column Inner Shaft Required +2 (Now Sourced)
PostPost by: jones+2 » Mon May 21, 2012 4:55 pm
Hello,
Does anyone know where I can get a new or second hand non collapsible column. The previous owner has used a metric set screw with no shoulder in the universal joint / coupling which has subsequently made a mess of the splines on the shaft.
jones+2
New-tral
PostPost by: Craig Elliott » Mon May 21, 2012 5:45 pm
I suspect you're going to have to keep an eye on the usual auction sites - unless the usual parts suppliers have recently started re-manufacturing them. It's also worth looking on the Triumph suppliers websites as I think both the early and late columns are Triumph sourced.
Good luck!
Craig Elliott
PostPost by: nebogipfel » Mon May 21, 2012 5:54 pm
jones+2 wrote:Hello,
Third item on the list looks like the one you need.....
http://www.rimmerbros.co.uk/Item--i-GRID005790
nebogipfel
PostPost by: jones+2 » Mon May 21, 2012 6:20 pm
Thanks John,
I saw that earlier but doesn't look the same. The one off my car is the same thickness right until the last ft where it becomes slimmer to connect to the coupling.
jones+2
New-tral
PostPost by: LotusElan+217 » Mon May 21, 2012 6:37 pm
PM sent
Founding member of the society to eradicate the belief that a +2 is not an Elan by those who really ought to know better :)
LotusElan+217
First Gear
First Gear
PostPost by: jones+2 » Mon May 21, 2012 9:07 pm
Part now sourced.
Thanks to everyone who took the time to respond to my request.
jones+2
New-tral
