Redoing steering wheel.
PostPost by: reb53 » Sun Aug 14, 2011 6:21 am
About 20 years ago I sewed a new cover onto my steering wheel.
Looked and lasted OK but have decided to do it again as it's getting a bit tired, but more annoyingly the packing underneath has gotten a little "soggy".
Intend to find some rubber hose of the right diameter, ( about 0.9 inches total ?), split it, glue it in place and then stitch the new leather on.
Anyone have a better idea for the core, or know what the original was ?
(And no, I'm not going to send it off to the other side of the World to get done, this wheel ain't leaving my sight.....)
Ralph.
reb53
PostPost by: billwill » Sun Aug 14, 2011 3:16 pm
Plumber's foam insulation for copper pipe might be better than hosepipe, as the latter might be too hard.
On the other hand, no idea how long such insulation might last..
A sheet of expanded neoprene (as used in wetsuits), cut into strips & wound & glued as a spiral wrap might be even better.
PostPost by: Sea Ranch » Tue Aug 16, 2011 10:16 pm
Cool thought with the neoprene, Bill.
Don't suppose Len Chandler would be willing to offer his tips/insights on how the pros do it?? Might be worth a try.
elan-f15/restored-steering-wheel-t19726.html
Randy
Sea Ranch
PostPost by: DeanG » Tue Aug 16, 2011 11:24 pm
This linke may help. http://www.eastwood.com/master-steering ... struc.html
Eastwood stuff is very good if somtimes a bit pricy. If nothing else looking at what the kit contains could give you a few good idea. A batch of epoxy and a leather steering wheel cover could do the trick for you. Good luck
DeanG
PostPost by: reb53 » Wed Aug 17, 2011 6:13 am
Thanks for the ideas guys.
You're right Bill, unless I get a softish rubber I could end up with something that is too hard .
Randy- Len's work is superb but I don't think it reasonable to ask him to share his trade secrets. If you're reading this Len and are happy to let me know what makes for a good core I'd be interested to know but suspect it would be a product that's not available here anyway.
I had a look at the Eastwood stuff Dean but it appears to be for repairing hard plastic type wheels rather than our type.
Ralph.
reb53
PostPost by: Frizer » Wed Aug 17, 2011 7:56 am
http://www.coachtrimmer.co.uk/ourwork-LotusElan.aspx
Maybe ask these guys if they can supply you the rubber?
type 36 (previous owner)
Frizer
New-tral
PostPost by: 612kiwi3333 » Wed Aug 17, 2011 7:14 pm
I redid my wheel with 5/8 heater hose split and covered in wheelskins leather cover. Feel is just right for me.
70 elan +2
71 europa
612kiwi3333
First Gear
First Gear
PostPost by: billwill » Mon Aug 22, 2011 8:12 pm
Purists will probably be horrified to learn that I can't abide the glare from the shiny bits of the steering wheel when driving away from the sun, so long ago I painted the spokes with matt black paint and I renew that from time to time.
Mine is not however a fancy signed wheel.
PostPost by: reb53 » Mon Sep 12, 2011 9:23 am
Just an update on my search for a steering wheel core.
Contacted Nick Fulcher here, ( thanks for the link),
and he was able to supply me with the correct moulded core of the type he uses.
Turned up in the mail this morning so now I have to dust off the needles and thread.
Thanks for all the suggestions,
Ralph.
reb53
PostPost by: reb53 » Sun Oct 09, 2011 2:46 am
Tis done !
Core arrived, was glued on, and good old youtube showed me how to do a baseball stitch.
Added some photos if, like me, you never knew what is in the centre of your wheel.
And yep, in the picture of the finished wheel that is a Maserati dashboard clock on my dash.
Seemed too good to not do anything with, and didn't need to cut or drill any holes to fit it.
DSCN1541.JPG and
Done ! Naturally the last bit of the stitching was the best...
DSCN1535.JPG and
You can see why the core really needs to have a square section internally.
DSCN1533.JPG and
What was found under the leather. Disintegrating foam.
reb53
PostPost by: elanfan1 » Sun Oct 09, 2011 7:55 pm
Hi Ralph,
looks like you did a really good job there. Did you find it difficult to do and how long did it take you. What leather did you use?
PostPost by: reb53 » Sun Oct 09, 2011 8:54 pm
Hi Steve,
Time consuming rather than difficult.
The best thing I did was to get a core off Nick Fulcher, (GBP 45, see earlier post).
It was a moulded soft rubber, ( type of silicon ?), that had been moulded as a tube and then split down one side, presumably to release it from the mould.
When glued onto the rim that split line made a good guide to keep my stitching straight, ( ish....).
I trimmed all the old foam off with a cobbled up hot wire cutter but left the foam between the two flat rims. Nick made a point of saying to leave it and I can see why. The rims would collapse towards each other if it wasn't there.
The moulding needed some trimming to fit around the spokes. When glued I wound masking tape around it to keep it in place. Despite doing that there was still a few small bumps but to my surprise the rubber sanded beautifully and I was able to tidy it up with very little trouble.
The leather I got off a furniture upholsterer which means it has been tanned and dressed with softness more in mind than longevity. So I don't expect it to last as long but it is so nice to handle that I don't mind doing it again in 15 or 20 years. Especially as I expect the core to last forever.
If there are any real upholsterers reading this, well now's the time for a shake of the head, followed by a laugh, because my stitching time was about 4 or 5 hours.....
Ralph.
reb53
PostPost by: billwill » Mon Oct 10, 2011 12:44 am
I did mine a few years ago, but retained the existing rubber.
The leather I used was a purchased wheel cover intended to be laced on.
Your stitching is neater than mine, but I too about that amount of time too.
:evil:
PostPost by: ardee_selby » Mon Oct 10, 2011 11:11 pm
reb53 wrote: If there are any real upholsterers reading this, well now's the time for a shake of the head, followed by a laugh, because my stitching time was about 4 or 5 hours.....Cheers Ralph.
Ralph,
Given the result, nobody has cause to laugh. It looks really very good.
It's something I don't think I would even attempt...no matter how many hours were available!
Out if interest was a special (waxed?) thread used?
ardee_selby
PostPost by: reb53 » Tue Oct 11, 2011 2:06 am
Hi Richard,
When I first did the wheel more than 20 years ago I had no trouble finding a braided, square section, nylon thread that was as strong as hell and laid nice and flat when used.
This time I spent all day, ( one of the perqs of being self employed), driving around the district before I got some off a canvas/leather business.
Went back later and got some more for the next time. So if this re-cover lasts 20 years, and I have enough thread for another, I guess I'm good for the next 40 years....... :)
Leather and thread cost NZ$20, or about GBP10.
Ralph.
reb53
