Steering column mount
It seems that the outer steering column in my car can be rotated a little too easily. I attempted to tighten the mount on the dash, but the studs are at the end of their threads. I put a few washers under the nuts, but the column is still not tight enough. This would indicate to me that this mount should be replaced.
Is this mount common to some other car? If anyone has specifics and availability it would be great.
- elancoupe
piss-ant wrote:which parts are you referring to? are they all there?
AHA! I was referring to the mount (#49), but after a check, it appears that I do not have #50, no wonder it's not tight. Thanks Gary.
Any ideas on sources? It looks like there is an unnumbered part above #50 as well.
- elancoupe
AFAIK it's all triumph spitfire/herald parts apart from the alloy casting that fixes to the rear of the dashboard. Rimmers stock some parts - link below.
http://www.rimmerbros.co.uk/Item--i-GRID005792
If I'm interpreting things correctly, the bits missing are felt pads. On mine they'd compressed over time and I replaced them with a thin strip of rubber between the column & the clamp, but if you want the OEM parts they're only a couple of quid from Rimmers.
UAB807F - Fourth Gear
Words tell a story, a picture sets the seen and the brain does the rest.
UAB807F wrote:AFAIK it's all triumph spitfire/herald parts apart from the alloy casting that fixes to the rear of the dashboard. Rimmers stock some parts - link below.
Thanks Brian. The part in question is actually a spring clip #609639, and is NLA from Rimmers, and others.
I found one place that lists then part as available, so unless someone stateside has a spare used one, I will follow up on that lead.
- elancoupe
