Bump Steer
PostPost by: jimj » Sun Aug 01, 2010 10:10 pm
If the shims between the chassis and steering rack were misplaced and bump steer ensued, what would the symptoms be?
Jim
PostPost by: miked » Sun Aug 01, 2010 10:20 pm
Jim,
You would have changes in direction as you rode over uneven road surfaces requiring contant subtle steering wheel input to correct. As I understand.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: elansprint71 » Sun Aug 01, 2010 10:31 pm
As the car rises or lowers on its suspension the car can steer to either side, and it is not always subtle. Before I changed my chassis full suspension compression resulted in an unexpected turn to the left; this was scary at high speed on undulating roads; especially the first time it happened. :twisted:
PostPost by: john.p.clegg » Mon Aug 02, 2010 5:48 am
Yep,when set up correctly,any movement from the norm should produce toe-in on both wheels,if set incorrectly one wheel can toe-in and the other toe-out,hence steering left or right over bumps/dips...
John :wink:
PostPost by: ceejay » Mon Aug 02, 2010 10:26 pm
And the fix is: Go get your self a book called "How To Make Your Car Handle"
By: Fred Puhn.
HP Books ISBN: 0-912656-46-8.
LCCC No:80-85270.
An excellent book for fine details about correcting all sorts of suspension problems.
No, I don't make money recommending the book. Fred knows he's stuff.
Check the contents PNG graphic out. (Sorry about the contents image size... biggest the system would allow)
You wont use everything detailed in the book, but there's heaps of good info there.
Col.
PS
Book could be out of print now?
how-to-make-your-car-handle-01.png and
PostPost by: mikealdren » Tue Aug 03, 2010 5:13 pm
I'll 2nd Col's recommendation. I saw an earlier review (maybe here?) and bought the book, it's excellent.
mikealdren
PostPost by: miked » Tue Aug 03, 2010 7:06 pm
Pete,
For the sake of being accurate, I never said the result was subtle, just the correction required. If someone is going to test a car I would have thought you build up speed over many surfaces and bends to find out the character of the car. Not just go "hell for leather" to find you have severe bump steer.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
