Steering Column Dismantling
Hi Andy,
If you haven't already, you'll have to remove either the top or bottom steering bush.
Some brute force and ignorance needed....
There is a 'shoulder' on the steering column shaft that catches on the bushes and stops the shaft coming out of the column.
As I remember it, there are 2 or 3 'nipples' on the bush that protrude through the column. If you push these in with a screwdriver then you should be able to pull (or push?) the column shaft through with the bush.
It was a year of two ago that I had to do this, so there could be something else there. But I think the major obstruction is/are the bushes.
Best of luck,
Peter
Best of luck,
Peter
'73 +2S 130/5
'73 +2S 130/5
peterako - Fourth Gear
With this column a few owners found that there was still a bit of movement even with new bushes so we put an extra bush in the top of the column; used a standard bush with the locating lugs shortened, cheers, John.
- AussieJohn
Andy, it really does make the job a lot easier and less chance off damage to the thin aluminium outer column if you have a special clamp to hold it in the vice.
Brian Buckland has details for one in his book. I have a photo of a wooden one somewhere on this forum. Have a search. It worked a treat.
Gerry
Gerry
- gerrym
Users browsing this forum: SENC and 15 guests
