Removable Steering Wheel
I used a Raceparts (UK) Ltd boss, code RTQ75Y with a 1'' dia blank slug for welding onto the column. This used a collar to release but is only suitable for a modern 6 bolt steering wheel. I will send you a pm with the raceparts page.
Lifeline (www.lifeline-fire.co.uk) sell a boss that fits a classic nine hole steering wheel but I do not know if they sell the slug, look under heading data sheet hole.
regards
andy
regards
andy
- batfish
You can try these guys: http://snapoff.com/
They have systems for Momo (6 bolt) and Monolita (9 bolt) both with and without key lock.
The flange has a stud pattern so you can?t interchange them.
A friend of mine has it his Elan, it works fine but moves the steering wheel about 20 mm closer to you.
Jannik
1969 S4-SE DHC
Eat one live toad the first thing in the morning and nothing worse will happen to you the rest of the day.
1969 S4-SE DHC
Jas - Second Gear
