Horn push on steering wheel
PostPost by: Phil W » Mon Jul 13, 2009 6:34 pm
My 1974 +2 130/5 has just passed its MOT first time again - for as long as I can remeber the horn has been activated by a flick switch mounted on the trim panel below the steering column as the black plastic plate that acts as the ground inside the upper part of the steering column had disintegrated. I'm determined to try and reinstate the correct function and have acquired a late Series V Triump Spitfire steering column for the purpose.
Looking at what's fitted to my Elan compared to the workhop manual I'm suprised to see that the horn doesn't seem to operate via a 'pencil' activated by pushing the centre boss but that the whole of the boss seems to be spring loaded. The boss is an integral part of the steering wheel and can't be removed as a separate item. It appears a metal ring makes permanent contact with one located on the plastic plate as the steering wheel is rotated and the circuit is completed by pushing the boss on the steering wheel.
I'm assuming that my 3 spoke steering wheel is non standard and was an after market fitment - although I've had the car since 1986!
Anyone got anything similar and can give some advice please?
Phil W
PostPost by: robcall » Mon Jul 13, 2009 10:24 pm
Your car most likely has the later steering wheel fitted late 1971 on.
Sounds like the car may have had a previous earth problem and been modified!
see-
elan-f14/sprint-horn-push-t13924.html
elan-f15/horn-comes-itself-t13693.html
Nigel Robertson
robcall
PostPost by: kcrossle » Tue Jul 14, 2009 2:35 am
My 1969 Plus 2 had the same "modification" - a toggle switch on the dashboard to operate the horn, which was how I bought it. In the recent rebuild it was discovered that the "brushes" which make the elctrical contact from pushing the horm button were broken. $15 US from rdent.com and it works a charm. Now I am looking for a use for that hole in the dash.
Keith
kcrossle
PostPost by: Phil W » Tue Jul 14, 2009 8:27 am
Thanks all.
I'm assuming there must be a wire somewhere that attaches to the 'fixed' brass ring located in the plastic plate below the steering wheel?
Phil W
PostPost by: paddy » Tue Jul 14, 2009 8:40 am
Phil W wrote:I'm assuming there must be a wire somewhere that attaches to the 'fixed' brass ring located in the plastic plate below the steering wheel?
On my steering column it is a single loose wire that is routed down the column, alongside the wires from each of the column switches. I think it is purple but I might be imagining that bit.
Paddy
1963 Elan S1
paddy
PostPost by: andyelan » Tue Jul 14, 2009 8:53 pm
Hi Phil
The link Elan/f14 shows what the steering wheel on your car should look like so if you've got all the bits, you should be able to get things working with the spitfire column ok. However, to get the horn to work, the column must be earthed to the steering rack and as there's a rubber joint in the column next to UJ unless if this is bridged with a wire you'll have problems. The difficulty is, getting to this uj with the carbs in place, that's why at the moment my car hasn't got a working horn
Andy
andyelan
PostPost by: Stuart+2 » Wed Jul 15, 2009 1:25 am
Andy
This joint is accessible from the front wheel well after removing the wheel.
I recently replaced mine and this was a relatively easy job with only minor contortions required.
Stuart - Sydney
1968 +2 50/1035
Stuart+2
PostPost by: Phil W » Fri Jul 17, 2009 9:32 am
Thanks all. Looks like a job for a wet weekend.
Phil W
PostPost by: alaric » Sun Jul 19, 2009 1:20 pm
Hi. As my steering wheel and horn switch are in bits I took a few pics and have attached them. I suppose the bits to note on the switch are the plastic top hats that insulate the top plate, the wire that pushes through the top plate - mine's shown not connected but it pushes through the hole in the top plate - I opened up the gap in the tube on the end of the wire to make sure it was a good tight fit. Then the brass screws that you push the steering wheel boss onto - if you overtighten them they'll break. I tested the assembly with a resistance meter once I'd put it all back together and it seemed to work fine. An earth on the steering column, as discussed above, is needed.
Hope that helps.
Sean.
horn push side on.JPG and
horn switch side on
steering horn push boss fixings.JPG and
horn push switch front
steering wheel boss in place.JPG and
steering wheel with boss ib place
alaric
