Steering rack
PostPost by: Petter Hval » Tue Feb 03, 2009 6:15 pm
Hi!
Can someone tell me where I can get shims for the inner track
rod ball joints? Sue Miller and P.M. don`t do them, and I can`t
find them in Rimmer`s Spitfire parts catalogue either.
Petter
Petter Hval
PostPost by: CBUEB1771 » Tue Feb 03, 2009 7:29 pm
Dave Bean Engineering (http://www.davebean.com/) lists these shims in .002" and .010" thicknesses in his catalogue. Moss Motors (http://www.mossmotors.com/) also lists them in the same thicknesses but for the Spitfire MkIV, not sure if they would be the same. I have no idea what either may actually have on the shelf. These would be fairly easy to duplicate from shim stock.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: mark030358 » Thu Feb 05, 2009 9:43 am
chic doig in Scotland has them. 2 and 10 thou.
PostPost by: jkatthehelm » Thu Feb 05, 2009 10:01 am
66 Elan fhc, 72 Elan Plus 2S 130/5, 98 Elise 2.0l Duratec
_____________________________________
Which way up should this be???
jkatthehelm
PostPost by: jkatthehelm » Thu Feb 05, 2009 10:02 am
jkatthehelm
PostPost by: gerrym » Sat Feb 07, 2009 9:29 am
For the Triumph steering rack, I've measured the inner track rod shims as 26mmOD, 17mmID. My shim pack thickness was 0.62mm (approx 24 thou) total.
Note, in case anyone has trouble obtaining these, ondrives has precison shims 25mm OD / 18mm ID.
Would probably work OK.
Gerry
gerrym
PostPost by: Petter Hval » Sat Feb 07, 2009 9:46 pm
Hi.
Thanks for the information.
Moss Europe, London, have the .002" shims but the .010"
shims are out of stock, so I had to order another 5 of the .002".
Petter.
Petter Hval
